Re: Looe Branch Line - timetables, cancellations, engineering work, closures and incidents
Posted by grahame at 16:43, 3rd February 2026
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 03/02/26.
It does NOT tell us what is expected on 4th February, of course!
We're now told
Alterations to services between Liskeard and Looe
Due to flooding between Liskeard and Looe the line is closed.
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 09/02/26.
Posted by grahame at 20:37, 2nd February 2026
Posted by TaplowGreen at 20:32, 2nd February 2026
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 28/01/26.
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 01/02/26.
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 02/02/26.
Posted by a-driver at 20:23, 1st February 2026
Part of the line is still underwater.
A lot of debris has been removed but there are some structures that still need inspecting once water levels drop.  Some other structures need inspecting but NR will allow trains to operate with a 10mph speed restriction.
They’re getting close!
Posted by TaplowGreen at 12:27, 1st February 2026
Posted by TaplowGreen at 20:42, 26th January 2026
Posted by grahame at 18:24, 25th January 2026
Posted by grahame at 09:54, 25th January 2026
In light of the torrential rain over the last 24 hours, and similar due for the next 48 hours, this doesn't bode well for re-opening anytime soon!
Now "end of the day" on 26/1/26
Will it ever reopen?  If this happens more frequently will it just become too expensive to keep open?
We should perhaps be grateful this didn't happen between the 1950s and the 1980s, as it probably would have been an excuse to close the branch.
Sounds like it needs some permanent resilience!
I would agree th sentiment .... but I have not seen any report of just how much remedial work is needed.    Is it a big job, or just a slow job?  I did note it took a long time even to have a specialist inspection.
There have been lines which have closed prematurely through catastrophic failure such as the old Caledonian route to Oban via Killin Junction (as far as Crainlarich) though that was already planned to go anyway.  Overseas, the line to Roscoff was still operational when it washed out and although I think it may remain (in theory) on the books of the French Railway network, prospects do not look good.
Posted by eightonedee at 17:43, 24th January 2026
Posted by TaplowGreen at 16:16, 24th January 2026
Posted by a-driver at 15:35, 24th January 2026
Posted by Pb_devon at 08:12, 24th January 2026
White water rafting, anyone?  [Image from here is not available to guests]
I did that on the Zambesi many years ago….maybe I should have waited to do it on the East Looe River!
Posted by AMLAG at 22:12, 23rd January 2026
Now "end of the day" on 26/1/26…
…that’s also dependant on a cl 150 unit being available !
Posted by TaplowGreen at 21:54, 23rd January 2026
Posted by Chris from Nailsea at 21:25, 23rd January 2026
Posted by GBM at 21:18, 23rd January 2026
Posted by GBM at 10:15, 13th January 2026
Looe branch now confirmed as being closed until the 23 January.
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 23/01/26.
Heavy rainfall during December combined with high tides resulted in the water levels at several bridges along the branch line being above the level which allows us to safely run trains. This had caused some damage to structures along the line which will require repairs.
The water levels dropped allowing Network Rail to inspect the bridges, and it has been found that repairs to the infrastructure are required before we are able to run trains again.
Storm Goretti brought strong winds and rain to the area overnight Thursday into Friday which has caused the water levels to rise again, which is now delaying the start of the repair work.
Once the water levels drop again, repair work will be able to begin, and we should then be able to give a more accurate date for the line reopening. Currently we do not expect to run trains until Friday 23rd January at the earliest.
Posted by Chris from Nailsea at 19:54, 12th January 2026
Thank you for your update post here, a-driver. [Image from here is not available to guests]
Posted by a-driver at 18:59, 12th January 2026
Posted by grahame at 08:53, 11th January 2026
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 16/01/26.
In more detail:
Once the water levels drop again, repair work will be able to begin, and we should then be able to give a more accurate date for the line reopening. Currently we do not expect to run trains until Saturday 17 January at the earliest.
We can question various aspects here ... and I note the words "at the earliest" which I take as being optimistic.  But at least there's a view a week ahead so that passengers can plan, and a better descipriton / text than might have been seen in the past.  And of course this (our) Internet ability to spread news means that all over the world means that in 2026 we are far more aware of a problem out of our own immediate home area than we would have been in 1926.
Posted by TaplowGreen at 08:17, 11th January 2026
Posted by Chris from Nailsea at 15:34, 9th January 2026
See member a-driver's post, just above here. [Image from here is not available to guests]
Posted by grahame at 12:08, 9th January 2026
Does anyone here know / is there any public information as to the scale of the damage and the consequential timelines?
The GWR update on storm rocovery just received includes:
The Looe branch line also remains closed due to flooding. We will provide a separate update on the Looe branch once we have a greater understanding of when the line will reopen.
Posted by grahame at 10:23, 9th January 2026
Following yesterday's storm, I'm wondering if the branch will be closed for several more days now.
Statements have always been in the negative - "Disruption is expected until the end of the day on 10/01/26" rather than "Services are expected to resume on 12/01/26" ... read carefully, I don't think any promise of when it will re-open has been given.    That's not an unreasonable stance, given that until the specialist divers took a look at least, the situation was unknown.
Posted by GBM at 09:24, 9th January 2026
Posted by a-driver at 08:47, 8th January 2026
There’s a lot of work that needs to be undertaken, possibly two weeks worth if not more.
There’s also planned engineering work closing the line from Monday 23 February to Friday 6 March
Posted by ChrisB at 08:31, 8th January 2026
That will depend on the work assessments needed on the bridges damaged
Posted by grahame at 06:44, 8th January 2026
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 10/01/26.
What it does not tell us is what happens after 10th January ...
Posted by TaplowGreen at 05:54, 8th January 2026
Posted by grahame at 20:55, 5th January 2026
The water levels have now dropped and Network Rail have been able to inspected the bridges. It has been found that some repair work will need to be carried out before we are able to run trains again. A further update regarding this repair work and when the line is likely to reopen will be given on Wednesday 7th January 2026.
Posted by plymothian at 10:50, 5th January 2026
Line to remain closed until at least the end of 07/01/26
Posted by a-driver at 08:10, 5th January 2026
The entire day's service on Monday now showing as cancelled on Journeycheck.
Divers have found defects with structures inspected, severity unknown.
Posted by bobm at 17:05, 4th January 2026
Posted by Chris from Nailsea at 12:27, 4th January 2026
From a quote within one of my previous posts on this subject:
The Liskeard to Looe branch line will be closed during New Year until the track can be safety checked by a team of specialised divers.
The branch line has been closed since Saturday 20th December because of floodwater although a replacement minibus service has been in operation.
The dive team arrived on site on Monday 22nd December but Network Rail said the water was still too deep and running too fast for the divers to be able to safely carry out the necessary inspections.
A Network Rail spokesperson said "The earliest that a dive team can attend the area again will be on Sunday 4 January. The line will remain closed until the divers have been able to check that it's safe to open."
If I were a professional diver, looking down into that swirling mass, I too would be politely reluctant to enter that floodwater, venturing into the unknown. [Image from here is not available to guests]
CfN. [Image from here is not available to guests]
Posted by grahame at 10:45, 4th January 2026
Latest update;
Even if divers are available on Monday 5th January 2026, it is quite possible that the line may not be safe to reopen.
The caution is reasonable in that the divers don't know what they will find.    The use of the words "even if" suggests to me that the divers might not even be booked to come and take a look!!
Posted by TaplowGreen at 09:14, 4th January 2026
Latest update;
We are working with Network Rail to re-open the line. The water levels have now dropped and Network Rail will need to inspect the bridges to make sure that the flooding has not caused any damage to the bridge structures.
As parts of the bridges below the water level need to be inspected, specialist divers are required but none are immediately available. Even if divers are available on Monday 5th January 2026, it is quite possible that the line may not be safe to reopen. Please check your journey as updates to the service may be made at short notice.
Posted by Chris from Nailsea at 12:53, 30th December 2025
An update, from the BBC:
Safety work closes Liskeard to Looe branch line
No flooding on the line at Sandplace railway station near Looe
Lesley Winfield has just moved with her family to Looe. "We were hoping to use the branch line but we've heard it's not that reliable and so he (her son) can't rely on it to get to his lectures so he has had to pay for accommodation and live there instead," she said. "It is very costly, a lot more costly than catching a train. If he needs to get to a lecture and he can't, he's scuppered really, so we can't take the risk," she said.
Looe resident Larry Shaw said "My son is coming down from Saltash tomorrow and he's had to make alternative arrangements. They've put public transport on to cover the trains but it's become a problem down here, you've only got to get a high tide and the tracks the first thing to flood. And it is Christmas so I don't think anybody would have been working," he said.
Cornwall Councillor for Looe East and Deviock Mark Gibbons said "The primary concern here is public safety we do have flooding on the line periodically and everybody is aware of this. The important thing to the people of Looe is not to try to blame when these things happen because obviously it's beyond our control but to make sure they are well managed and looked after as passengers and that businesses don't suffer," he said.
A Network Rail spokesperson said: "The line was shut once the water levels reached the closure marks on the bridges and viaducts along the route in the early hours of Saturday morning (20th December). In order to reopen the line, specialist divers are required to inspect the lower part of the structures to ensure they haven't been affected by scour. We're sorry for the disruption to journeys. Road replacement transport is in place and passengers are advised to check with National Rail Enquiries or Great Western Railway for details of these alternative travel arrangements."
Posted by GBM at 08:33, 28th December 2025
Cancellations to services between Liskeard and Looe
Train services running to and from these stations will be cancelled. Disruption is expected until the end of the day on 04/01/26.
Journeycheck explains
Heavy rainfall over the last few days combined with high tides has resulted in the water level at several bridges along the branchline being above the level which allows us to safely run trains. As a consequence Looe Branchline train services are Cancelled.
As parts of the bridges below the water level need to be inspected, specialist divers are required.
There are no divers available until the 4th Jan 2026.
Train services running to and from these stations have been suspended. Disruption is expected until the end of the day on 05/01/26.
KINDLY NOTE - The Liskeard to Looe branch line has no scheduled service on a Sunday at this time of year. The details shown below are what we anticipate will be in place from Monday 29th December until the line reopens.
Posted by grahame at 04:50, 28th December 2025
Posted by GBM at 07:31, 23rd December 2025
Posted by Oxonhutch at 20:15, 19th December 2025
For those of us who don't have otters in our garden, have you a more general comparison?
I think he is referring to a fish's wallet.
Posted by grahame at 19:41, 19th December 2025
It has been wetter than an otter's pocket here over the last week.
Posted by Kernow Otter at 19:29, 19th December 2025
Posted by GBM at 08:44, 19th December 2025
Sat, 20 December 06:55 Liskeard to Looe due 07:25
20/12/25 06:55 Liskeard to Looe due 07:25 will be cancelled.
This is due to flooding.
Closed all day it seems
Posted by Chris from Nailsea at 20:57, 29th June 2025
From Cornwall Live:
Trains cancelled in Cornwall due to herd of cows
All trains are cancelled between Liskeard and Looe
A large herd of cows on the railway in Cornwall has cancelled train services between Liskeard and Looe this afternoon (Sunday, June 29). The herd of cows was reported between Sandplace and Looe, suspending the Looe Branchline.
All trains running between Liskeard and Looe will be cancelled. Disruption is expected until 5pm.
Great Western Railway said: "We apologise for the disruption to your journey today. A large herd of cows has been reported on the railway between Sandplace and Looe which means that the Looe Branchline is suspended.
"Rail replacement transport has been requested but not yet confirmed. During this disruption if you wish to use local buses as an alternative means of transport and the local bus is not accepting GWR tickets please purchase a ticket on the bus, keep it and send it, together with your train ticket, to us to claim for a refund."
Train service has since returned to normal.
Of note is that actually relevant image from Cornwall Live.
Posted by a-driver at 07:49, 16th June 2025
Probably true. It has the shortest journey time by road, good roads as well, so you don’t need a lot of coaches….. which would be a struggle to source on a Sunday, and the majority of journeys will be end to end.
Indeed - and here's another comment I heard - think it related to Coombe Junction but it could have been Bere Alston - that there are staff members not strong enough to work the points, so that restricts who can be rotaed. If someone can answer to / talk to me on that rumour it would be appreciated.
In my opinion, that is pure rubbish.  Hand points don't require much strength to operate.  In respect of the Coombe Junction working, it's probably more strenuous going from ballast to train/train to ballast then operating the points...... and if you struggle going from ballast to train/train to ballast then you won't be considered fit to work trains.
Posted by a-driver at 07:45, 16th June 2025
It’s definitely not the easiest to bustitute.
Coombe Junction, st keyne wishing well, and Causeland are completely inaccessible to a bus. Especially the ones that GWR have on standby for Cornwall mainline and branches today (a 15m triaxle coach)
But very few passengers will travel to Coombe Junction, St Keyne Wishing Well and Causeland.  A taxi is provided for the handful that require those stations.
Posted by LiskeardRich at 19:02, 15th June 2025
GWR had years to address this issue when it was in their control before the DfT tightened their grip. Instead of doing so they left it on the "too difficult" pile.
It's never been within GWR's control.  That was the whole point of privatisation!
It's been suggested on another forum that Liskeard-Looe is often the first branch to be sacrificed on a Sunday when there is crew shortage as it's the easiest one to bustitute.
Falmouth has the sea shanty festival with huge queues seen today, they had 1 coach on standby which would have been as good as useless, how do you decide which 53 passengers to move, and upset the rest.
Posted by grahame at 17:35, 15th June 2025
Posted by a-driver at 16:32, 15th June 2025
Posted by TaplowGreen at 15:44, 15th June 2025
Posted by ChrisB at 14:53, 15th June 2025
What do you think the future holds for local Rail User Groups when it's all owned and run by the nation?
That is a superb question.
"What do you think" ... I think (I know!!) that I don't know enough about what the future holds.  I can visualise good and bad scenarios; the question comes do we [just] wait and see or do we look to partner and persuade in what gets set up or not, and in what authority it has.
Partner with who(m), exactly?
Posted by a-driver at 13:18, 15th June 2025
Posted by TaplowGreen at 12:52, 15th June 2025
Due to a shortage of train crew between Liskeard and Looe the line is closed.
Train services running to and from these stations may be cancelled. Disruption is expected until 15:00 15/06.
Due to crew shortages, we are unable to run train services today.
An astonishing failure ... on what would be a peak early summer's day.   Should someone come back and explain that there's a local transmitted flu or something else that has struck all the crews in the last 24 hours, this service decimation is "unforgivable" ... but of course it will probably get forgotten in the mists of time and the fog of the next issue.
Two questions when something goes wrong:
1. What lessons will be learned from today?
2. How will those lessons result in actions which make sure this should not happen again?
1.  Lessons were learnt a long time ago.
2.  “7-day railway” discussions have been ongoing for sometime, unfortunately the DfT  won’t release any further funding to resolve the issue. They want to continue with the “cheap sticky plaster” fixes which we all know doesn’t work.
The issue isn’t with GWR. GWR run the operation as per the contract outlined by the DfT.  It’s for the DfT to sort.
Posted by grahame at 11:17, 15th June 2025
Posted by a-driver at 11:10, 15th June 2025
I look forward to the time that everything is owned and run by the nation so there won't be (sometimes correct) buck passing.  I just fear that the nation will follow the time lines taken by the DfT which is the nation and things will get done far far far too slowly if at all.
Posted by grahame at 10:53, 15th June 2025
Posted by a-driver at 10:46, 15th June 2025
Posted by TaplowGreen at 09:45, 15th June 2025
Multiple cancellations today due to crew shortage - the type of sunny weekend summer day when branch lines such as this get the chance to really show their worth, but GWR have failed to provide anyone to run them.
1) Judging by the repetition in similar circumstances across the region over a number of years, none.
2) They won't. GWR are staggering towards the end of their franchise, there is little or no motivation for them to make the efforts required.
Posted by grahame at 08:57, 15th June 2025
Posted by TaplowGreen at 08:06, 15th June 2025
Posted by ChrisB at 12:15, 6th March 2025
I think my point is that the poor person catching that train - assuming a regular - was *only* catching it because they *had* to - presumably unable to alter their start time - coz you would, wouldn't you if you could.
So they are entitled to a massive amount of notice I feel, rather than the normal few weeks. Like a year or thereabouts, in order that a property move to somewhere more suitable (Liskeard?) with continued links might be easily organised.
Posted by grahame at 12:09, 6th March 2025
This obviously is a very different kettle of fish ...
I am - totally - in agreement with that and all you say, Richard; my comment you picked up on was in answer to a question asked.
We lost out 05:33 at Melksham to Swindon which was also a quiet train and did not fight it nor suggest alternative provision ... first train is now 07:21.  Loss of the earliest or latest journey opportunities is a serious matter reflected also on the passengers onward, return and inward journeys and whilst you do not have to have every individual service making stand alone economic sense (a mistake made in the Beeching era?), you do need to reconsider services that are a severe drain on the viability of the line and sometimes make these decisions / acceptances.
Posted by RichardB at 11:21, 6th March 2025
Then that is what they should do.
Indeed they should.
Out of interest, has that ever happened elsewhere? (providing a taxi for a regular traveller who loses their regular service and has no other feasible choice for their regular journey).
When trains were withdrawn from the Sinfin branch, taxis were provided for the regulars for a number of years until official closure procedures had been completed.
This obviously is a very different kettle of fish.  The new first train will simply be one hour later.  Hopefully anyone inconvenienced by this (and I'm sorry if they are) will be able to negotiate a later start time with their employers if necessary.  Despite what "Plymothian" says, I don't believe there is a very regular passenger.
The hard truth is that running a train for just one person is simply untenable and since the new time is just an hour later, it's also untenable thinking about a taxi or anything else.   As we all know, the Looe line is heavily subsidised and we have to get a bit real about transport economics here.
The changes will generally be an improvement and I believe will attract more passengers to the line.  The Looe line's main traffic is daytrippers and tourists.  Looe itself is a small place - just 5,000 or so population, about half of whom are of retirement age - and the main line at Liskeard is just 8 or so miles away.  Anything we can do to get more locals on the train year-round is clearly a good thing, year-round daytrippers and tourists too.  We at the Partnership do a lot of promotion of the line, particularly online e.g. via targeted paid adverts on Facebook - you can see examples on our page here  https://www.facebook.com/greatscenicrailways  We're planning significant promotion of the May timetable which will, as well as all the online stuff, include leaflets delivered to households in Looe and the surrounding area by the Royal Mail.
One more thing to consider - in the next few years, some quite serious investment in the Looe line will be needed.  As things look now, battery trains will need either a West Ealing style charging set up or even overhead being installed in Platform 3 at Liskeard.  The more the railway, we at the Partnership and others can do to help increase year-round usage of the line, the easier that funding decision becomes.  I don't think for a moment we might be looking at closure of the line but making sure trains, particularly at either ends of the day when they are most expensive to run, are decently used will be key, I'm sure.
Posted by REVUpminster at 08:56, 6th March 2025
If they did provide a taxi and three other customers heard about and paid the rail fare GWR might even make a profit.
Posted by grahame at 21:19, 5th March 2025
Indeed they should.
Posted by froome at 20:28, 5th March 2025
Indeed they should.
Posted by ChrisB at 21:21, 4th March 2025
Posted by LiskeardRich at 21:36, 3rd March 2025
1 person doesn’t make a service viable. It would have been cheaper for GWR to send a taxi for that passenger every day than to run the train.
Posted by ChrisB at 20:47, 2nd March 2025
Each to their own but it really isn't a good use of resources to run a train that is used by just one person.  It's not same person every day and the few people who ever take that train may well be using it because the next one currently gets them to their destination just too late e.g Plymouth at 09 08 and will find the 07 33 will work fine for them.
And that 1 passenger does use that train every day.
Hmmmm. someone is mistaken. I hope that 1 person doesn't lose their job owing to the loss of the service.
Posted by grahame at 07:41, 28th February 2025
I feel for that 1 passenger on the 0630. First & Last trains should be sacrosanct if *anyone* is regularly using them, since you can guarantee that they're only on them regularly if they *have* to be on them.
It's no small thing to cut the first or last trains.
Having said that, we did not fight GWR's decision to cut the 05:17 Westbury to Swindon (05:33 at Melksham) a couple of years back - first train now 07:05 from Westbury / 07:21 from Melksham.    We lost the ability to get to London at 7 a.m. which (however) we had only had for a couple of years.  A big concern was that it knocked out long distance (and lucrative) journeys being a "peak" train, and knocked out return journeys on other trains that were running anyway.   What we did ask for (and have received) was an extra train at the other end of the day and the 21:16 from Westbury (21:32 at Melksham) is new.  I was on it last night - 2 car train, about 10 in my carriage, half of whom got off in Melksham - not busy but ten times the passengers I ever saw on the 05:33.   Huge care needed - but this might well be the right decision for Looe; I trust RichardB to be fully informed and to have let us know this change is one to work as a modernisation for the future with, rather than protest.
Posted by RichardB at 23:25, 27th February 2025
Posted by plymothian at 20:07, 27th February 2025
Posted by ChrisB at 16:52, 27th February 2025
Posted by AMLAG at 20:40, 24th February 2025
What a pity it’s taken these D&CRP inspired TT improvements (and resultant train operating cost reductions) so long to be implemented; it should have happened several years ago.
Posted by Chris from Nailsea at 12:19, 24th February 2025
Thank you for posting that advance notice here, RichardB.  [Image from here is not available to guests]
Posted by RichardB at 11:07, 24th February 2025
There will be changes to the Looe timetable from May to provide much better connections at Liskeard to/from Plymouth throughout the day, a good pre-09 00 arrival in Plymouth for commuters and a better spread of request stops at Sandplace, Causeland and St Keyne.  This follows local requests and liaison between ourselves (Devon & Cornwall Rail Partnership) and GWR.
The aim is to provide 6 (or near to) minute connections out of Looe and the same for inward except out of London services where the aim is to provide 10-13 minute connections. The exception is the last connection of the day from London where 20 minutes has been deliberately allowed for robustness.  Currently day trippers from Plymouth to Looe on the key services have more than 20 minutes at Liskeard in both directions.
To enable these changes, the number of trains a day will reduce from 15 to 13.   The first train will leave Looe at 07 33 instead of 06 30 now.  The 07 33 will give a Plymouth arrival of 08 44 with a 6 minute connection at Liskeard.  We and GWR have counted passengers on the line’s service and the existing 06 30 is little used (indeed the September Tuesday we did our counts, there was just one passenger).  Currently you can either arrive in Plymouth at 07 43 or 09 08.   The new 08 44 arrival should be attractive.
A further bonus of the new timetable is that the last train will leave Looe at 21 55 on weekdays, 18 minutes later than now.   This will make a 7 minute connection at Liskeard for Saltash and Plymouth.
Posted by Chris from Nailsea at 20:24, 23rd February 2025
I know: I was, as usual, looking for something else when I happened to stumble across this historic topic.  [Image from here is not available to guests]
Thankfully, the car driver in that particular incident was not seriously injured. Just a bloody nose, apparently.
Our frequent readers should know by now that the use of such clearly irrelevant images, in otherwise factual news articles, is something that winds me up somewhat.  It's just shoddy journalism.  [Image from here is not available to guests]
Posted by LiskeardRich at 19:36, 23rd February 2025
No, it's one of their 'stock photos of a train' at Bristol Temple Meads again, isn't it?  [Image from here is not available to guests]
Your reply is almost as late as GWRs trains in Cornwall today  [Image from here is not available to guests]  [Image from here is not available to guests]
Posted by Chris from Nailsea at 19:04, 23rd February 2025
Posted by GBM at 05:35, 20th September 2024
Due to the sea flooding the railway between Liskeard and Looe the line is blocked.
Train services running to and from these stations may be cancelled. Disruption is expected until 08:30 20/09
Posted by Pb_devon at 07:46, 2nd September 2024
But at the penalty of Yardees being late for work!!
Posted by GBM at 04:05, 2nd September 2024
05:57 Liskeard to Looe due 06:27
02/09/24 05:57 Liskeard to Looe due 06:27 will be cancelled.
And the return run.
But help is on its way
06:19 Par to Plymouth due 07:21
02/09/24 06:19 Par to Plymouth due 07:21 will be terminated at Liskeard.
It will no longer call at Menheniot, St Germans, Saltash, St Budeaux Ferry Road, Keyham, Dockyard, Devonport and Plymouth.
Posted by TaplowGreen at 06:47, 1st September 2024
Train services running to and from these stations will be cancelled. Disruption is expected until the end of the day.
........Newquay-Par branch also wiped out.
Posted by bobm at 12:41, 31st August 2024
Took a while - but now done.
Posted by Pb_devon at 07:55, 31st August 2024
TG, I’ve suggested mods amend thread title to reflect issues posted beyond 26 August.
Posted by TaplowGreen at 07:44, 31st August 2024
And again............
Due to a broken down train earlier today between Liskeard and Looe:
Train services running to and from these stations have been suspended. Disruption is expected until 10:36 31/08.
Posted by REVUpminster at 07:10, 28th August 2024
The 175s primary job is to get rid of HSTs. They will go on Barnstaple and Okehampton.  The 19 150s at Exeter are diagrammed to rotate through the Cornwall branches stabling overnight at various locations in Cornwall before working back to Exeter. The 150s seem to be becoming very unreliable.
The 175s I don't think can be cleared for the Cornwall branches. The 158s at Exeter are likely to go to Bristol.
Paignton-Exmouth will still need at least 4 turbos and 175s occasionally as 158s are used now when short of stock. The Barnstaple/Okehampton 175s will stable at Exeter, in place of the 158s overnight before having to work back to Laira.
Posted by RichardB at 05:58, 27th August 2024
A two car unit has left Laira depot for Liskeard to resume the branch service with the 11:36 to Looe.
Obviously sad to lose the earlier services (especially the 10 36 ex Liskeard) but good to see that, once that unit had arrived, the full service was provided for the rest of the day.
Posted by bobm at 11:17, 26th August 2024
Posted by grahame at 08:02, 26th August 2024
A victim of BBQ Sunday yesterday, and Bank Holiday Monday today so......
Due to more trains than usual needing repairs at the same time between Liskeard and Looe the line is closed.
Train services running to and from these stations will be cancelled. Disruption is expected until 12:00 26/08.
Gosh - I hadn't noticed yesterday.
I guess (tell me if I'm wrong) that this is caused by a trains failing / short term fault ("broken down train") and, sure, these things happen occasionally.  But it highlights how thinly resourced and specialised our railway is today.  No dropping off a carriage or two off a train that calls at Liskeard ... and it sounds like there isn't another anywhere in the Plymouth area.  Should the main line be run with class 175 trains next year, perhaps we'll see a 4 or 5 car main line train being reduced by 2 cars in the event of a branch line failure.  Is that part of the plan?
Bank holiday Monday.  It's cloudy and just 14 degrees in Looe this morning , rising to 19 by lunchtime, Some clouds in the sky, which are expected to clear shortly and it will be a lovely if cool morning.
Posted by TaplowGreen at 07:45, 26th August 2024
A victim of BBQ Sunday yesterday, and it's Bank Holiday Monday today so......
Posted by ChrisB at 08:06, 7th November 2023
GWR tweeted that taxis are being supplied at Looe & at Liskeard.
Posted by GBM at 07:29, 7th November 2023
Due to a train hitting an obstruction on the line earlier today between Liskeard and Looe:
Train services running to and from these stations have been suspended. Disruption is expected until 09:30 07/11.
The 05:57 Liskeard to Looe service struck a tree in the Causeland area. The train was able to continue its journey but some damage was caused which requires an inspection by one of our engineers. Until this is carried out the service on the line between Liskeard and Looe has been suspended.
Posted by stuving at 11:34, 1st November 2023
It's reported that it was 2Q08 - the Network Rail Track Recording Unit (950001). Oh dear - meant to be non-destructive, isn't it?
It's last shown as leaving Liskeard P3, so perhaps the crew, not being regulars, hadn't realised they had to check the ground frame before entering Coombe. That could certainly cause a points failure, which is NR's current description. The TRU wouldn't have any reason to go to or towards Moorswater, would it?
Posted by Mark A at 10:52, 1st November 2023
Good point. Seems that Realtimetrains date for things involving Looe branch is a bit awry at the moment - e.g. the site's not flagging the passenger service as cancelled today.
Posted by GBM at 10:34, 1st November 2023
It derailed, but went through to Par later on?
Surely if it derailed, it would stay there until lifted back on track, etc.
Seems to have arrived at Par 0613
Posted by Mark A at 10:21, 1st November 2023
Posted by bobm at 09:35, 1st November 2023
Overnight a train has derailed on the Looe Branch.
It appears the train continued past Coombe Junction Halt towards Moorswater and derailed on catch points.
The branch is closed as a result.
It is the latest disruption on the line after flooding near Looe has closed it on several occasions in recent days - and is set to do the same over the next two days.
Posted by grahame at 22:57, 24th May 2023
At least they 'explain' there not-quite-right picture.  An IET to Looe seems unlikely, even in many years time when they're on gentler duties like the castles now are.
