| Re: Split tickets - rule details Posted by grahame at 16:52, 9th February 2026 | ![]() ![]() ![]() |
(I have refrained from copying any detail from the post which contains information from a Staff Brief)
There is some concern over tickets being changed which will be less of an enhancement and more of a refund and rebook - which might to serious things to passenger's cash flow and result in a higher total price paid in the end.
As an example, I sometimes buy a super-off-peak Melksham to London return via Swindon, but on my return find that either I want to come back off-peak, or via Westbury. In the past, I have been able to excess my ticket - pay just the difference. What for the future?
I notes this comment that I will share. Very true.
I agree, this is the big problem with changes to the NRCoT, in that they are totally unadvertised. While I suspect that most people are totally unaware of the NRCoT in the first place, they will expect to be treated the same as in the past. Even those who are aware of the NRCoT, won't be reading them every time they purchase a ticket, and so may get caught out.
| Re: Split tickets - rule details Posted by Fourbee at 16:19, 9th February 2026 | ![]() ![]() ![]() |
On 4. - What if you book and then find that the conditions have changed? Yes - a little more unlikely that questions 1 and 2 which will (1) and have (2) been pertinent to my own journeys.
There is some explanation of that here https://www.railforums.co.uk/threads/forthcoming-changes-to-national-rail-conditions-of-travel.293598/page-19#post-7661681(I have refrained from copying any detail from the post which contains information from a Staff Brief)
| Re: Split tickets - rule details Posted by Mark A at 15:31, 9th February 2026 | ![]() ![]() ![]() |
Splitting at a request stop versus a set down / pick up only stop. A request stop is a stop, I'd imagine that to be fine. Despite the train not stopping at them, pick up / set down only are not 'Stops' so it makes sense that they do not count as far as split ticketing goes.
(And now for some reason I'm thinking of the mailbag pickup/set down apparatus for a travelling post office, can't help it, sorry...)
| Re: Split tickets - rule details Posted by grahame at 14:50, 9th February 2026 | ![]() ![]() ![]() |
1. Sorry, your 'either' is correct - you are changing onto a rover ticket, STJ being a station that it is valid at?.
Thank you - I was having trouble working out what "first" and "last" stations meant on a rover ticket at a junction.
| Re: Split tickets - rule details Posted by ChrisB at 14:22, 9th February 2026 | ![]() ![]() ![]() |
| Re: Split tickets - rule details Posted by grahame at 12:45, 9th February 2026 | ![]() ![]() ![]() |
1. yes
2. Not all stations are splitting stations, so unless you find one, don't worry about it.
Question 1 was an "either / or" - good to have a positive answer Chris, but which of the alternatives I asked about was it "yes" to?
Question 2 I HAVE previously found - at the example I used (Sugar Loaf) and the train crew were less than amused.
3. Probably there for future use too enable a ticket T&Cs 'simplification'
4. Looking for them on the National Rail website - only the current version will feature
| Re: Split tickets - rule details Posted by ChrisB at 12:18, 9th February 2026 | ![]() ![]() ![]() |
1. yes
| Split tickets - rule details Posted by grahame at 10:10, 9th February 2026 | ![]() ![]() ![]() |
From National Rail - Conditions of Travel / latest edition of 23rd November 2025
Unless Condition 14.1 applies, if you are using a Season Ticket, daily Zonal Ticket, or another area based Ticket such as a concessionary pass, ranger, or rover, in conjunction with another Ticket and the last station at which one Ticket is valid and the first station that the other Ticket is valid are the same, then the train does not need to Call at that station for your combination to be valid.
1. How are "first" and "last" stations defined?
If I am travelling from Melksham to Chester, am I allowed to use a Melksham to Severn Tunnel Junction ticket and transfer there to an Explore Wales ticket even if the train coming through the tunnel from the Pilning direction does not call until Newport? Does STJ count as the "first" station on the rover, even though it's valid from Cheltenham Spa, or do I need to drop back at Temple Meads off the Trowbridge to Cardiff service onto the Exeter to Cardiff service?
2. The NRCOT these days has a clause about pick up and set down only stops at ticket split stations - as I understand it, you can't do a split at such stops. It has still not clarified in my mind the status of splits at request stops such as Sugar Loaf - do you need to ask the train crew to stop to make your split valid?
Some Tickets specifically exclude their use in conjunction with other Tickets. This will be made clear in the terms and conditions when buying such Tickets.
3. Scratching my head looking for examples. Probably missing the obvious ... and does that mean that if you have such a ticket from - say - London to Pewsey - that you could still carry on travel on the same train if you get off and get straight back on again?
4. NRCoT has a start date but no expiry date. How does the customer know whether or not the version quoted above if the current one?
