Server slow ...
Re: Server slow ...
Posted by stuving at 12:35, 6th November 2025
Not just this site, of course. I've mentioned OpenRail before; the landing page there now says:
Recently the website has suffered from high loads, believed to be due to AI crawlers. Regrettably I have therefore had to restrict access to registered users.
It's a free and open registration, so only for load limiting purposes. Further down, it says:
Security Advice
Security is mediocre at best on this website. When choosing a username and password, don't select anything you use for other sites.
Which is candid, at least.
Re: Server slow ...
Posted by grahame at 07:07, 6th November 2025
I have made a number of changes / tweaks over the past fortnight, and symptoms like that should now occur only very, very rarely.  Many of the changes made mean that our front of house receptionist / manager is now picking up loads more casual and repeated enquiries rather than passing them on though to our worker server.
But, sadly, I have failed to identify what it is that's causing the spikes and ironically because the worker server now has a lower general load the spike can climb further before it cuts off.  You will at times see slow responses.  With the worker so busy during these spikes, it's almost impossible to log in to it and look around, the problem being gone before I can actually have that look around.  There are *some* helpful patterns ....
I *think* I have now identified what's been causing the problem load spike issue, and in the process also made some other efficiency changes.
Main change / issue: We have 9Gb of archived documents (and that will continue to grow) for our search engine to look through, and over 300,000 individual public posts to check too. And such searches are none-trivial. They are welcome - however, it would appear that at least one well known search engine (not Google) has been making lots of search requests and indeed with terms that are WAY off topic. A couple of lines of code mean that we now send a quick and polite reply when an automata searches for things like (and these are real searches from the hours before I made the change):
* MyFloridaMarketPlace abbreviation
* housing lawyer in penang
* Napoleon Dynamite Live reviews
* melinda breslin townsend louisville ky
* 2m tv documentaire region du sud
* wer ist emilio frazzoli unfall
While I was at it ... I have an image library containing 20,000 plus different images, a handful of which are called up frequently and consistently.  They are managed by our worker server which is the one that loads heavy, but I have now mirrored around 50 of them on the receptionist server to allow that machine to answer queries without reference to the worker.    Yesterday, with that change in place, our receptionist served 3,000 images of which perhaps a third were done without reference to the worker.
Here's the worker loading as of an hour ago - solid black line is today's
There will continue to be spikes, including server management and database backup operations but I don't want to see them going off the scale.
Re: Server slow ...
Posted by grahame at 17:30, 29th October 2025
I think I must have done something it didn't like:
Not you ... heavy loading.  Ongoing experiments looking into the load spikes. In the meantime, I repeat my suggestion that LONG posts are copied before you press "post" or "preview" just in case
Re: Server slow ...
Posted by CyclingSid at 15:03, 29th October 2025
Warning: mysqli_query(): MySQL server has gone away in /home/firstgreatwestern/include/ipfind.inc on line 41
Warning: mysqli_query(): Error reading result set's header in /home/firstgreatwestern/include/ipfind.inc on line 41
Warning: mysqli_fetch_assoc() expects parameter 1 to be mysqli_result, boolean given in /home/firstgreatwestern/include/ipfind.inc on line 42
Warning: mysqli_fetch_assoc() expects parameter 1 to be mysqli_result, boolean given in /home/firstgreatwestern/include/ipfind.inc on line 89
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
Re: Server slow ...
Posted by grahame at 12:11, 23rd October 2025
I guess the attached screenshot is a symptom of this sort of problem?
Yes ... some very interesting patterns at present; research ongoing.
I have made a number of changes / tweaks over the past fortnight, and symptoms like that should now occur only very, very rarely.  Many of the changes made mean that our front of house receptionist / manager is now picking up loads more casual and repeated enquiries rather than passing them on though to our worker server.  This (Adobe, license, bought!) image is one I'll be using to help explain the various servers into the future.
But, sadly, I have failed to identify what it is that's causing the spikes and ironically because the worker server now has a lower general load the spike can climb further before it cuts off.  You will at times see slow responses.  With the worker so busy during these spikes, it's almost impossible to log in to it and look around, the problem being gone before I can actually have that look around.  There are *some* helpful patterns, but I'll need to shut down some segments of service to help isolate the problem.  Good news for members is that I can do that when the Coffee Shop is quiet - that is during the night - there may be occasions in the early hours in the next week or two when responses will be abnormal.
Re: Server slow ...
Posted by grahame at 17:20, 7th October 2025
Re: Server slow ...
Posted by matth1j at 15:05, 7th October 2025
Re: Server slow ...
Posted by grahame at 09:00, 4th October 2025
Brief update - a few days ago (at the turn of the month) we hit 1 million requests of our receptionist server in a 24 hour period. Of those, over 350,000 were passed on to the worker server.   Requests yesterday were down to 750,000 of the receptionist with just over 250,000 passed on to the worker server.
By taking requests that are clearly not in our interest to invests heavy resource into answering, and sending back brief responses politely saying "nothing much for you here", we have been able to persuade some of the requesters to limit their asking - hence the drop in traffic levels.   I am not resting on my laurels here and there remain occasions - particularly when the databases are backing up, and when an "overenthusiastic" automata gets going - that still push our worker server's capability to the extreme.
Re: Server slow ...
Posted by Witham Bobby at 10:17, 24th September 2025
Again, I thank you for all the effort you put in to keep this lively and interesting discussion site going.  Grand job!
Re: Server slow ...
Posted by grahame at 10:10, 24th September 2025
Positive headine - 4,000 requests in the last 24 hours for pages from UK addresses which I can identify as probably being from real people looking at pages on via main server.  That's a fantastic ongoing number - it's actual pages to Coffee Shop content and is in addition to pages served "light" by the receptionist server which I will look to quantify in due course.
But that is 4,000 requests out of 200,000 (or out of 350,000 if you add in requests for style sheets, images, Jacascript file etc) and out of 700,000 requests to the receptionist!    I am posting this update on the "server slow" thread because it's all those extra numbers that are or have been flooding out the real responses for our substantial numbers of members and human guests - posting as something of an explanation.
For us armchair viewers you get a sense of the problem and how it is escalating when you see there have been 2497 "users" on line today - and the record since the forum started is 2526 and that was only a fortnight ago.
For the 4,000 requests I guesstimate we should be showing between 50 and 200 users online in that statistic - varying depending on time of day.  We have a few members and guests active in the early hours, and many more during the day.  We do need to add to that the visits from useful indexing crawlers such as the GoogleBot which are vital to us finding new people to look at our data.  Ideally, the numbers showing for "users" would have a running rate of between 350 and 700, and our servers "spec" should allow for - my guess - around 1,000 without serious response degradation.    Currently, numbers have returned to being in that ideal / target range with some filtering added in very recently.
Re: Server slow ...
Posted by GBM at 11:06, 22nd September 2025
You could perhaps offer your server to the various airlines currently struggling with an attack!
Re: Server slow ...
Posted by grahame at 09:32, 22nd September 2025
Adjustments to our algorithms have reduced those numbers in recent days to about a third of what they were when you commented on the peak, BobM.   But it's an ongoing 'game', and care needs to be taken to ensure we don't throw out the baby with the bathwater - or in this case the member with the unwanted automated spiders, some of which are masters of disguise.
Some traffic levels up 3000% ... yes, 30 times what they were a week ago ... and no great surprise that the responses have been a bit slow over the weekend.  In fact the surprise, perhaps, is that the server has "toughed it out".
Re: Server slow ...
Posted by grahame at 10:04, 19th September 2025
Re: Server slow ...
Posted by grahame at 09:10, 9th September 2025
I got a non-responsive return when requesting this page just now....
Since 03:30 this morning on our worker server:
on our worker server 56123 requests of which
38313 good requests
17708 planned diversions
102 erroneous requests
0 server failures
on our receptionist server 126024 requests of which
106093 good requests
18940 planned diversions
777 erroneous requests
214 server failures including (ChrisB) your "server gone away" response
214 in over 100,000 is more than I like - but it is only about 1 in 500 requests.  I will echo - good idea to copy / paste locally long posts before you submit and that's general internet advice.
Re: Server slow ...
Posted by ChrisB at 08:48, 9th September 2025
Re: Server slow ...
Posted by grahame at 08:27, 9th September 2025
Information post - purely out of interest for members
The subject is "server slow" and not "server broken" - and it has been slow overnight ... such a classic case of an overenthusiastic automated crawler, from not one but a whole suite of hosts.
So that's up to 6 pages per second.  Where do they come from?  Let's look an example:
8.160.129.10 IP info & Whois online
Host Name: Undefined. Country: China. City: Beijing. Coordinates: lat: 39.911; lon: 116.395. Network: 8.160.128.0/22. Type: Hosting Spam rate: 28.00%
We have a wonderful resource at the Coffee Shop ... which means a wonderful range of pages published - and the word "public" is there in the very word "published".   I have tools which help me notice - often without but sometimes with manual intervention - these heavy automated uses, even if (as in this case) the requests pretend to be human / don't admit to being crawlers.   They may not be noticeable looking at each individual hit ... but I can see patterns
Note - the first report is BST and the second GMT - so they are at different times; the second report is after I referred 8.160 requests back to the receptionist to reduce automata load on our worker server.  The changes last December which added the receptionist have given me this capability
EDIT to add - about an hour later - here is a "classic" denial of service 'attack' just flagged up
Re: Server slow ...
Posted by grahame at 15:08, 5th September 2025
As an aside, do you know how important coffee is?  Coffee is vital for survival.  Dinosaurs didn't have coffee, and look how that turned out.
CfN
Indeed - and as a more recent example, from Coffee Aid:
Largely through the efforts of the British East India Company and the Dutch East India Company, coffee became available in England no later than the 16th century according to Leonhard Rauwolf's 1583 account. The first coffeehouse in England was opened in St. Michael's Alley in Cornhill. The proprietor was Pasqua Rosée, the servant of Daniel Edwards, a trader in Turkish goods. Edwards imported the coffee and assisted Rosée in setting up the establishment. The Grand Cafe in Oxford is alleged to be the first Coffee House in England, opened in 1650 by a Jewish man named Jacob. It is still open today, but has since become a popular Wine Bar.
And I don't know anyone who was around before 1583 and is still around today - without cofeee they have all perished.
I note that the Grand Cafe has been open rather longer than our Coffee Shop - we will never catch them up.  However, they are now a wine bar and whilst we may do a bit of whining here too, I hope we always have a dominant positive vibe!
Re: Server slow ...
Posted by Chris from Nailsea at 13:41, 5th September 2025
I continue to thank grahame for providing all of us with the Coffee Shop forum.
... we have a fabulous voluntary team of moderators and admins, with a membership who are naturally helpful - so there is rarely need to buy extras in beyond coffee beans ...
CfN
Re: Server slow ...
Posted by grahame at 12:00, 5th September 2025
prices quoted look like somewhere over (and perhaps well over) a doubling of monthly fees
Who pays those fees - is it out of your own pocket Graham? I haven't see any adverts to fund the site.
The Coffee Shop and other ran on spare capacity on the servers I used to use as "Well House Consultants" - my IT company that ran from 1996 until a few years ago, and those servers still host legacy sites though they become less relevant.  I love(d) doing the IT stuff and the transport stuff, so asnwe closed down the businesses I have taken on the server costs - for all the sites combined- as a hobby thing.     You can see all the various sites via https://www.sheepbingo.co.uk/error/errorpage.php and if things go almost totally belly-up, it's where you are taken.
My background / career was working with stuff like this, and in addition we have a fabulous voluntary team of moderators and admins, with a membership who are naturally helpful - so there is rarely need to buy extras in beyond coffee beans, and using open source software tends to employ more of my volunteer time than commercial software would,  but saves an awful lot of costs that would-be associated with a commercial and supported setup, and reduces our dependencies on others.
Re: Server slow ...
Posted by matth1j at 11:29, 5th September 2025
Re: Server slow ...
Posted by grahame at 09:16, 5th September 2025
To give you a comparison - this running traffic level in 10 times the maximum I would expect in any month.
As a side issue with our (new, moved) hosting space provider,  I asked about adding resource to the virtual server as that would be something of a fix.    That would mean a move off the legacy contract which is in place and a rebuild - possible but prices quoted look like somewhere over (and perhaps well over) a doubling of monthly fees as well which is not an attractive solution, especially at it just raises the lid - potentially - until next time the pan overflows.   So just resizing is neither a long term nor a financial solution.
Edit to add - I will be following up with thoughts within members areas
Re: Server slow ...
Posted by bobm at 20:36, 4th September 2025
Re: Server slow ...
Posted by grahame at 19:53, 4th September 2025
4th September 2025
A huge spike in traffic - described elsewhere - but it's starting to effect performance.   I *think* I can isolate a lot of the traffic involved over the next 24 hours - however, as I work on the system you may find that I over-trap some traffic.
If you get error messages for a few minutes over the next few days, or messages telling you ...
A quick answer from our receptionist
You have arrived in a spiderflood from a remote address. If you are a real user, and you keep getting this message, please get in touch with the admin team (address below).
please give me 30 minutes or so before your report it ....
Re: Server slow ...
Posted by grahame at 19:18, 18th August 2025
Our server load is going "through the roof".   But - it's a bit of a "careful what you wish for".  One of the hoped for consequences of going to https (six months ago!) was to make the pages more secure-looking and encourage crawlers ... and they are crawling.   I note Google and Alexa spiders have been especially active over the last couple of days and I am keeping an eye in others.  Here are the browsers that called for over 1000 Coffee Shop responses yesterday
14676 Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; bingbot/2.0; +http://www.bing.com/bingbot.htm) Chrome/116.0.1938.76 Safari/537.36
39550 Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; Amazonbot/0.1; +https://developer.amazon.com/support/amazonbot) Chrome/119.0.6045.214 Safari/537.36
5139 Mozilla/5.0 (compatible; DotBot/1.2; +https://opensiteexplorer.org/dotbot; help@moz.com)
7000 Mozilla/5.0 (compatible; SemrushBot/7~bl; +http://www.semrush.com/bot.html)
3314 Mozilla/5.0 (compatible; BLEXBot/1.0; +https://help.seranking.com/en/blex-crawler)
1146 Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36
1290 meta-externalagent/1.1 (+https://developers.facebook.com/docs/sharing/webmasters/crawler)
1806 Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36; compatible; OAI-SearchBot/1.0; +https://openai.com/searchbot
1817 Mozilla/5.0 (compatible; MJ12bot/v1.4.8; http://mj12bot.com/)
1074 Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/129.0.0.0 Safari/537.36
3828 Mozilla/5.0 (Windows NT 10.0; Win64; x64; trendictionbot0.5.0; trendiction search; http://www.trendiction.de/bot; please let us know of any problems; web at trendiction.com) Gecko/20100101 Firefox/125.0
3575 newspaper/0.9.3.1
Re: Server slow ...
Posted by grahame at 15:18, 2nd August 2025
An update on this one - still being well and truly spidered and no single nasty culprit.  I have made a few ongoing adjustements while static here in Mosjoen - but on the road (or should I say rail?) again from tomorrow and I expect to be mobile for another week or so.
Receptionist and worker loads:
Views from just up the road - one looking forward and one looking back
And even here there are things that remind me of England, and of my home town
Re: Server slow ...
Posted by grahame at 17:47, 18th July 2025
"Server slow" but perhaps different reasons.  The number of spiders crawling our site has been creeping up - to some extent as expected once we moved from "http" to "https".   As I see individual spiders adding a significant load, I at taking a look at those that come onto my radar and asking (or forcing) some of the more noisy ones not to index our content.
In terms of web searches, 19 out of 20 in the UK use Google and the Googlebot is allowed Coffee Shop access just as any human guest might be (so no indexing of things like Frequent posters) but others such as Yandex and Petal which are not widely used in the UK are turned away.  Ironically, Google does not put a big load at all on when indexing - I see it, but it's not effecting performance like (for example) the Petal crawler was earlier today.
It's not just web search indexers that crawl sites ... there are a variety of other companies indexing and selling data to their customers or making use of it within products - from plagiarism identifiers to AI feeds and Search Engine Optimisation tool and link reporters.  In some cases they may do us a bit of good, but as we're not driven by sales volume and income here, and we're very much UK based when they tend to index worldwide, that good if it's there tends to be tangential.
It's a bit of an ongoing game - others play it too and have things like "Captcha" - "are you really human" test which we could do if we need to.   We do have some logic that spots aggressively or characteristically automated visiting without the need for users to tell us which boxes have motorcycles or stairs (or GWR class 158s!) in them from time to time.   Please let me know if you get a "you are not really human" type message more than very rarely!
Re: Server slow ...
Posted by grahame at 14:07, 24th May 2025
Noting that our server is suffering a denial of service attack - 44 requests PER SECOND.   Dealing with it as best I can from where I am (I'm on a train - in Lithuania!)
OK - dealt with ... the heavy black line is today's worker server load.  Looks dramatic - there was (perhaps) a handful of proper requests that may not have been answered but the server did not fall over.
If you wonder how I find out there's a problem like this, the server sends me a message
Now in Vilnius
Server slow ...
Posted by grahame at 11:32, 24th May 2025
