| Re: Frome station - facilities, services, improvements, events and incidents - merged posts Posted by John D at 13:27, 22nd June 2026 | ![]() ![]() ![]() |
Due to a points failure at Frome all lines are blocked.
Impact:
Train services running through this station will be cancelled or running non stop between Castle Cary and Bruton. Frome will not be served. Disruption is expected until 14:15 22/06.
Impact:
https://www.gwr.com/travel-information/travel-updates/live-network-updates
| Re: Frome station - facilities, services, improvements, events and incidents - merged posts Posted by John D at 15:26, 2nd April 2026 | ![]() ![]() ![]() |
Looks like massive expansion of Frome has just been approved by Secretary of State, 1700 houses, 2 care homes, employment land, shops
Land bounded by railway and bypass
https://www.gov.uk/government/publications/called-in-decision-land-south-of-frome-bounded-by-marston-road-b3092railway-line-and-a361-frome-bypass-and-including-land-to-the-south-of-a361-r
| Re: Frome Disruption 04/09/24 Posted by Chris from Nailsea at 21:12, 4th September 2024 | ![]() ![]() ![]() |
There tie ping could benifit from a bit of spill chucking, tho
| Frome Disruption 04/09/24 Posted by Witham Bobby at 16:54, 4th September 2024 | ![]() ![]() ![]() |
Cancellations to services at Frome
Due to urgent repairs to the track at Frome the line is closed.
Train services running through this station may be cancelled. Disruption is expected until 17:30 04/09.
Due to the closure of a section of track near Frome for engineering works, we are currently unable to serve Frome station for the time being, in either direction.
Specialist teams from Network Rail are on site trying to resolve the situation, but in the mean time if you are boarding at Frome, please make use of the Help Point to speak with a member of staff.
We apologise for the inconvinience this afternoon.
If you require further information please speak to our staff at the station or on the train, use the Customer Help Point, tweet us @GWRHelp or call National Rail Enquiries on 03457 484 950.
Last Updated:04/09/2024 16:48
So it seems that trains can run on the Avoiding Lines, but not through the station on the Main
| Re: Signalling problems at Frome 01 Apr 24 Posted by GBM at 09:08, 1st April 2024 | ![]() ![]() ![]() |
Due to a fault with the signalling system at Frome fewer trains are able to run on some lines.
Train services running through this station will be cancelled or delayed. Disruption is expected until 10:00 01/04.
Customers at Frome heading towards Bristol Temple Meads and London Paddington are advised to travel onwards to Westbury, where there is a shuttle train service operating between Westbury and Frome. The same advice applies to any customers at Frome looking to travel South towards Weymouth of Portsmouth.
| Re: Signalling problems at Frome 01 Apr 24 Posted by bradshaw at 07:43, 1st April 2024 | ![]() ![]() ![]() |
Journey chech shows a Westbury -Frome shuttle is in place this morning, while the Weymouth services travel via the avoiding line
Sounds like a good idea
06:18 Yeovil Pen Mill to Filton Abbey Wood due 08:29 (not calling at Frome)
06:38 Weymouth to Gloucester due 10:02 (not calling at Frome)
06:50 Westbury to Weymouth due 08:23 (not calling at Frome)
07:25 Westbury to Frome due 07:34 (additional service)
07:33 Weymouth to Gloucester due 10:56 (not calling at Frome)
07:44 Frome to Westbury due 07:55 (additional service)
08:03 Bristol Temple Meads to Weymouth due 10:32 (not calling at Frome)
Additional services as below
08:25 Westbury to Frome due 08:34
08:52 Frome to Westbury due 09:03
08:52 Frome to Westbury due 08:59
09:15 Westbury to Frome due 09:24
09:30 Frome to Westbury due 09:41
09:30 Frome to Westbury due 09:37
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by infoman at 07:14, 1st April 2024 | ![]() ![]() ![]() |
Impact:
Train services running through this station will be cancelled or delayed. Disruption is expected until 07:30 01/04.
Due to a track circuit failure at Blatchbridge Junction , some trains from Frome maybe cancelled or delayed. GWR apologies for any delay to your journey today.
GWR apologises for an delay to your journey that this may cause you.
If you arrive at your destination 15 or more minutes late because your GWR train was delayed or cancelled, you can claim Delay Repay compensation.
https://www.gwr.com/help-and-support/refunds-and-compensation/delay-repay
ALSO problems between Swansea and Cardiff due a power supply issue.
| Re: Frome to Bath Spa, end of the afternoon, with a cycle Posted by stuving at 11:36, 20th October 2022 | ![]() ![]() ![]() |
I like the phrase
I presume like when the other half asks where I am going on the bike, "I am following the front wheel". Potential for seeing some where different, or differently.
Accidentally cycled to Frome.
My first thought on reading that was Frank Spencer ...
| Re: Frome to Bath Spa, end of the afternoon, with a cycle Posted by CyclingSid at 07:02, 20th October 2022 | ![]() ![]() ![]() |
I like the phrase
| Re: Frome to Bath Spa, end of the afternoon, with a cycle Posted by Mark A at 14:53, 19th October 2022 | ![]() ![]() ![]() |
It does, and I'm trying to think of another example. Some of the over bridges on the line from Radstock are quality constructions too.
It's curious that if we count the moribund track on the line to Radstock, what was the Wilts, Somerset and Weymouth railway network, despite its occasionally poorly sited stations, has retained track over practically its entire length.
I didn't realise that the Frome avoiding line was opened as late as 1933. It's not even seen its centenary, let alone any catenary.
| Re: Frome to Bath Spa, end of the afternoon, with a cycle Posted by Bmblbzzz at 11:08, 19th October 2022 | ![]() ![]() ![]() |
From Bath to Frome I'd used the Sustains path from Radstock much of which is on the old railway. Somehow, it shares the railway with the track, which has not been lifted, but after the weather of the last few years the installation is a monument to the flexibility of earthworks and indeed railway track. The track itself has in many places slowly moved itself - particularly to the inside of curves on embankments, where it now teeters on the edge of the earthwork.
I've never been to Frome on the train but riding alongside the old track still, more or less, in place, is one of the best aspects of that particular path.| Re: Frome to Bath Spa, end of the afternoon, with a cycle Posted by IndustryInsider at 10:56, 19th October 2022 | ![]() ![]() ![]() |
Lots of routes have very poor track quality at the moment thanks to the extremely dry summer.
I can’t remember a time since the aftermath of the Hatfield crash and the ‘cyclic top’ chaos when there have been more TSR’s across the network. It makes keeping time so much more difficult so is impacting on performance.
And if there’s no TSR needed it’s a still a rocky and bumpy ride in places…though a good excuse to try and blame ‘the new trains’ for ride quality I suppose!
| Frome to Bath Spa, end of the afternoon, with a cycle Posted by Mark A at 10:44, 19th October 2022 | ![]() ![]() ![]() |
Accidentally cycled to Frome. Thankfully I'd checked the timetable, because after the 16:24, Frome has a 2 1/2 hour gap before the next train.
An hour before the train to Gloucester, there's one in the Weymouth direction, so a few people for that, after which Frome station, well maintained, spotless, was deserted. At one point, the sound of a train horn, nearby, suggested that something had just left the line from the quarry.
The cafe-in-a-shed across the road was closed (it's a tiny business, it closes at 3) and the bakery/food/drinks place had closed at three too, 'cos bakers are up early. Neither of the DIY sheds at the station has a cafe so a bit of a gap there given that the station approach if not the station itself remained busy as it's the location for a cluster of small businesses.
Cometh the hour, cometh the people and five minutes before the train was due the platform was reasonably busy, as was the train when it arrived.
The journey worked well, though not as well as returning from Avonmouth with a bike the other week. The Avonmouth train had a pretty flexible space for luggage and cycles. The Frome train was a 166, space for just 2 bikes and with a notice on the trains exterior to that effect. The official cycle capacity of 2 bikes was immediately full at Frome with myself and another who was heading for Trowbridge. The train's two bike cycle space was just too short for my bog standard touring bike, the other cycle person sat on the luggage rack and constrained his machine beneath that - and any more people travelling with bikes would have been testing whether the train manager had a pragmatic attitude to things.
Class 166s, even idling, are fantastically noisy from the platform, and Frome, with its overall roof, is a particularly good place to appreciate this aspect of their design. The racket they make isn't brilliant from within the train either it has to be said.
Once on the train, there was something that might have been a sobering continuation of something from the cycle ride. From Bath to Frome I'd used the Sustains path from Radstock much of which is on the old railway. Somehow, it shares the railway with the track, which has not been lifted, but after the weather of the last few years the installation is a monument to the flexibility of earthworks and indeed railway track. The track itself has in many places slowly moved itself - particularly to the inside of curves on embankments, where it now teeters on the edge of the earthwork. Turning to the cycle path surface, it appears to have been laid without a membrane beneath it - which can help mitigate earth movements - and the surface is in many places torn longitudinally as the earthwork has settled and spread. In the forty years or so since the line has seen a train, several of the under bridges now preserve the original trackbed levels while to either side the trackbed has dropped a few inches.
Which brings me back to the return on the train, and experiencing the same issue but on a live railway line. Between Westbury and Trowbridge there were a couple of places where the train rolled and spiralled noticeably giving the impression that we were on a piece of track with, thanks to this summer's heat and drought, a issue of subsidence and sideways displacement.
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by infoman at 18:31, 9th March 2022 | ![]() ![]() ![]() |
featured on ITV West on wednesday 9th March approx 18:18pm
available on plus one at 19:18pm
| Re: Frome station promotion leaflet Posted by grahame at 11:16, 8th October 2019 | ![]() ![]() ![]() |
Great Western Railway: Sally Falkingham sent apologies but reported that she would be attending a meeting in Trowbridge on 27 September to discuss the future of the Community Rail Partnership covering the Weymouth to Westbury and Bristol line. Kelly Flynn would also be attending.
Does anyone know anything about this?
A little. The Heart of Wessex CRP is changing after the retirement of Catherine Phillips. The subject of how any Community Rail activities on Weymouth - Westbury - Bristol that it was undertaking are continued and in what form, funded by whom and organised / administered by whom were discussed. Attendees were invited from, I believe, the other CRPs who operate (anywhere) in Wiltshire, GWR, and local government interested parties. Not a public meeting by any stretch of the imagination (quite an exclusive group?) so not added to the forum diaries. With no Catherine around, I'm not sure who represented ongoing HoW CRP interests for station groups, etc.
| Re: Frome station promotion leaflet Posted by bradshaw at 09:55, 8th October 2019 | ![]() ![]() ![]() |
Ref Heart of Wessex
WEST DORSET WESTERN AREA TRANSPORT ACTION GROUP (WATAG)
Extract from September meeting
https://transportactiongroup.files.wordpress.com/2018/02/111-sept19.pdfDoes anyone know anything about this?
| Re: Frome station promotion leaflet Posted by grahame at 06:31, 29th August 2019 | ![]() ![]() ![]() |
Hi All
I volunteer my services at the "Discover Frome Information Point" (ie tourist office run by Frome Town Council FTC) on certain days. There is currently no timetable summary for Frome available and we are obliged to hand out the B1 booklet. ...
It does sounds that public transport use in and from Frome could be encouraged by the provision of better easy to understand data. Elements of that have been provided in the past - but either decisions have been taken to discontinue so doing, or they have simply fallen by the wayside. Not sure that it's anyone's "responsibility" or even that all transport operators would be required to co-operate; at least 2 train and 3 bus to my knowledge, and I may have overlooked some.
On the positive side there is indeed still a current A-Z table on display at FRO. This is a single poster size display. I will attempt a photo after my arrival on the anticipated 20.07 tomorrow and send it to Graham if it might be of use. I do a fairly regular trip from Leatherhead to FRO on many Thursdays but last time the FRO direct got cancelled (due to crew shortage!).
For the immediate request for this Saturday - thank you, but not enough time to produce anything. For the longer term (release for December 2019 timetable change??) would be useful to know what destinations are currently shown - whether it's been changed from the original a couple of years back.
On Frome buses - also note that the D2 changes from next Monday - with alternate buses going each way round Frome and known as D2A. This has caused disquiet as certain timetable sources show D2 reduced from every 30 minutes to every 60 minutes ... until the reader realises there's a new table D2A.
| Re: Frome station promotion leaflet Posted by WSW Frome at 20:16, 28th August 2019 | ![]() ![]() ![]() |
Hi All
I volunteer my services at the "Discover Frome Information Point" (ie tourist office run by Frome Town Council FTC) on certain days. There is currently no timetable summary for Frome available and we are obliged to hand out the B1 booklet. As many know this does have a BRI-WEY summary in the rear but as I advise my enquirers this is not the complete service from FRO which is only shown in the main table. Hardly user friendly but does show all the FRO extras.
FTC previously produced a summary leaflet for all BUS services from Frome but this has now been discontinued. So they will not be doing one for trains.
| Re: Frome station promotion leaflet Posted by grahame at 16:07, 28th August 2019 | ![]() ![]() ![]() |
Is there an A-Z destination sheet(s) at Frome? If so, start off by taking a phone photo of it/them & using that data?
I'm not sure if there currently is - the issue of information for Frome station arose in the good old days when Catherine was the HoW CRO, I did the job on TransWilts, NR was station manager at Westbury and AM was in publicity at GWR; we got together to produce the first A-Z for Frome; a small station for such as sheet but one of a handful of special cases where it's logical.
I did wonder about seeing if there's still a sheet available - but scale is an issue and there never was a corresponding Z-A (there or anywhere). Really something for the people who have taken over from all four names listed above to do, or decide that it's not a good use of their resource to do.
| Re: Frome station promotion leaflet Posted by ChrisB at 16:00, 28th August 2019 | ![]() ![]() ![]() |
| Re: Frome station promotion leaflet Posted by grahame at 15:38, 28th August 2019 | ![]() ![]() ![]() |
You could make it a lot more use by including arrival times at the destinations you have listed.
One of the most common queries is "I know what time I want to be where....but what time do I need to catch a train to get there then?"
Totally agreed. And sadly I could take a 20 minute automatic exercise forward into a whole day's project ....
Just quickly plotting sources and destinations is interesting ... shows what a presentation nightmare Frome is. The exercise is based on a fairly casual enquiry - I can take it further should it be further encouraged, otherwise I have plenty to do! But IMHO, Frome does need a good local sheet - to include details at far end and at key stations for all services - Westbury, Trowbridge, Bath Spa, Bristol Temple Meads, Filton Abbey Wood, Bristol Parkway, Cheltenham Spa, Yeovil Pen Mill, Dorchester West, Reading.
| Re: Frome station promotion leaflet Posted by ChrisB at 15:29, 28th August 2019 | ![]() ![]() ![]() |
| Re: Frome station promotion leaflet Posted by grahame at 15:14, 28th August 2019 | ![]() ![]() ![]() |
Been mucking about ... http://www.passenger.chat/frometrains.pdf ... difficult bit is how to automatically cover intermediate stations!
| Re: Frome station promotion leaflet Posted by grahame at 08:48, 28th August 2019 | ![]() ![]() ![]() |
I have a request for a leaflet to hand out this Saturday to promote services from FROME. It seems to be in B10, B1 and T7 from GWR and table 20 from SWR. No Heart of Wessex line guide this year as I understand it. Any suggestions? Surely I have missed something!
Grahame, when I showed you a A4 leaflet on yellow paper, black print, you said you had one. This was in connection with a previous statement regarding the non production of a Heart Of Wessex Line Guide this summer. Would that cover the request made to your goodself.
Sounds like the Bradford-on-Avon sheet. An excellent local timetable for that station.
If I or someone had the time ... a black and white print on a pastel paper document could be produced - estimate volunteer work time 1 day - good thought that you lead me towards. Problem to ensure accuracy. Seen too many cases of inaccurate leaflets that are a laughing stock and worse, even with "E&OE" on them.
| Re: Frome station promotion leaflet Posted by martyjon at 08:36, 28th August 2019 | ![]() ![]() ![]() |
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by grahame at 08:14, 28th August 2019 | ![]() ![]() ![]() |
| Re: Frome (and Trowbridge) to Bristol - 77 minute delay Posted by RA at 22:24, 14th January 2019 | ![]() ![]() ![]() |
09:25 Frome to Cardiff Central due 11:36
09:25 Frome to Cardiff Central due 11:36 will be started from Bristol Temple Meads.
It will no longer call at Frome, Heywood Road Jn, Trowbridge, Bradford-On-Avon, Avoncliff, Freshford, Bath Spa, Oldfield Park and Keynsham.
This is due to a problem currently under investigation.
There will be a replacement bus for this service which will operate between Frome and Trowbridge where passengers will be able to board the 11:06 Trowbridge - Cardiff Central service.
Problem being lack of passenger facilities at Heywood Road Junction
09:25 Frome Not Stopping
09:49 Trowbridge Not Stopping
09:55 Bradford-On-Avon Not Stopping
09:58 Avoncliff Not Stopping
10:00 Freshford Not Stopping
10:12 Bath Spa Not Stopping
10:15 Oldfield Park Not Stopping
10:22 Keynsham Not Stopping
10:40 Bristol Temple Meads 10:40
etc
etc
So that's "catch the train 77 minutes later" at Trowbridge. But good on JourneyCheck for giving that specific information. What is the advise for people who would have started at 09:49 at Trowbridge?
TransWilts is bustituted again today - finishing off works at Westbury ... I would have hoped that
Set booked to stable at Frome overnight. Unfortunately the set had to run empty back to Westbury sidings as Frome station was under an engineering possession. This would have been fine if the lines through Westbury weren't in another engineering possession all day Sunday!
| Frome (and Trowbridge) to Bristol - 77 minute delay Posted by grahame at 09:18, 13th January 2019 | ![]() ![]() ![]() |
etc
etc
| Re: An analysis of Frome Posted by WSW Frome at 09:56, 30th September 2018 | ![]() ![]() ![]() |
For the sake of completing the normal and wide destination list from Frome. The 17.24 FRO continues to WAT via WSB. The 15.06 FRO after arriving at Yeovil Pen Mill continues swiftly to the Junction and WAT. Another destination is SOU on Saturdays (06.49) and on many Bank Holiday Mondays!
For the anti-clockwise SWR services, the electronic systems tend to show the destination as WSB, when in fact they all continue to SAL or WAT. The services receive a new reporting number at WSB so never mind the customers!
The article in the "Frome Times" was a little strange. This may reflect journalistic licence or alternatively some aspect of the actual meeting held at Somerset County Council. Having participated in the Somerset Travel Consultation exercise, I noted that it contained some rather strange aspirations especially with budgets very constrained. For rail, priorities included some wilder re-openings and the "Race to the West" saving a very few minutes. However, there were other positives.
I hope to speak to the representatives from Frome Town Council to find out exactly what happened.
| Re: An analysis of Frome Posted by TonyK at 09:54, 30th September 2018 | ![]() ![]() ![]() |
A very good analysis, grahame. The service for Frome is a bit like the Severn Beach was in the Olden Days, where you had to work some pretty unusual hours to be able to commute. That got mended, but Frome might be a bit more awkward, being on that loop. All roads do not, alas, lead to Frome.
| Re: An analysis of Frome Posted by paul7575 at 18:39, 29th September 2018 | ![]() ![]() ![]() |
Incremental improvements are needed, after all, Frome wasn’t built in a day...
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by grahame at 16:44, 29th September 2018 | ![]() ![]() ![]() |
I got somewhat carried away answering a Facebook post based on a Frome Times Article
Frome Town Council, led by resilience manager, Anna Francis and cllr Sheila Gore, are lobbying Somerset for a better railway service.
Anna recently attended Somerset County Council’s rail workshop for regional directors in Taunton. She was there to highlight the need for better rail services and links in Frome and the wider area. Somerset only has nine stations and Frome is the only town with a station in Mendip.
I'm not sure whether Somerset County Council are the best or only people to lobby but anyhow I wrote:
On Monday, trains leave Frome with final destinations of London Paddington. Cardiff, Filton Abbey Wood, Weymouth, Bristol Temple Meads, Swindon, Warminster and Yeovil Pen Mill. Trains arrive also from London Waterloo and Yeovil Junction, but there are no direct trains from Frome to either of those. Looking across a whole week (and at times that engineering works are not reducing train runs), there are also trains or from Bristol Parkway, Weston-super-mare, Gloucester, Worcester Shrub Hill, Worcester Foregate Street and Great Malvern. Ironically, the only place not served by a direct train whe it could be is the county town of Taunton. Many of the services are slow. None of them is frequent. And chances are that if there's an outbound one that suits you down to the ground, the return service won't be so perfect and you may need to change trains. Fares are at best erratic - there are some excellent / sensible fares, and some that will make you squeal in horror - but it's not all that easy to see the wood for the trees, in other words to discover how you can change your plans a little to save a lot using the fares that the railway markets - so (in theory) wants you to use.
Is this situation right / appropriate for the residents and businesses of Frome, and for people wanting to visit the town? If not, can it be improved?
I live in Melksham and visit Frome from time to time - so I'm not unaquainted with the town, and travelling to and from there. Melksham is broadly comparable in population to Frome but (can you believe) five years ago we had just two trains each way per day. Miss the 07:20 to Swindon and the next train was 19:47, miss the 06:38 to Westbury and the next train was 19:15. We have managed to have our service improved - it must be admitted only up to about the level that Frome enjoys - but we are seriously talking with the parties involved in specifying and providing the service about the next steps. It can be done. Key for us has been singleness of purpose - we have been specific in routes and requests, and co-ordinated around the town. We have worked closely with our council even though they have been budget constrained and not always as rail aware as we would wish. We have worked with other towns up and down the route and indeed beyond to help put forward united suggestion that mean that one train serves multiple flows - not all of them Melksham. And we now have an established track record of improvements on which to build further.
South Western Railway under its new franchise that started last year was required to report to the Department for Transport on what to do about the Yeovil to Bristol corridor - and they ran a consultation looking for inputs in January. I hope you made your views known. But if not, don't worry; things don't change overnight and if the town gets consistently lined up behind enhancement proposals they have a better chance. Do your groups all work with the Heart of Wessex CRP which has a mandate for your line and station? Are you members of TravelWatch SouthWest - the region's campaign and partnership co-ordination group? If not ... timing is perfect as their general meeting is next Saturday in Taunton. http://travelwatchsouthwest.org
Members thoughts here (and signups for Taunton
) most welcome| Re: Points Problem at Frome Posted by bobm at 20:57, 22nd August 2018 | ![]() ![]() ![]() |
It has.
Original problem caused by a freight or engineering train running through the points.
| Re: Points Problem at Frome Posted by froome at 20:56, 22nd August 2018 | ![]() ![]() ![]() |
If a train booked to call at Frome skips it via the avoider it will show as delayed between Blatchbridge and Clink Road junctions as the system "loses" the train when it diverts from its booked route. It will also show as delayed if the system detects it hasn't moved for 10 minutes or so. In the later case it stops the automated announcements going off every 60 seconds as another minute is added to the delay.
Thanks. My friend actually arrived ok with little delay, so I'm guessing this incident has been resolved.
| Re: Points Problem at Frome Posted by bobm at 13:56, 22nd August 2018 | ![]() ![]() ![]() |
| Re: Points Problem at Frome Posted by froome at 13:34, 22nd August 2018 | ![]() ![]() ![]() |
The current train running towards Westbury and Bath is just showing as delayed. However, I'm assuming once that train can get through, trains will run from Weymouth to Westbury missing out Frome without too much delay. A friend of mine is due on a later train this afternoon, so just checking if that is the case.
| Re: Points Problem at Frome Posted by SandTEngineer at 12:44, 22nd August 2018 | ![]() ![]() ![]() |
.....or in the case of the recent derailment in Long Rock Depot, what they don't do.....
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by Timmer at 10:19, 22nd August 2018 | ![]() ![]() ![]() |
From JourneyCheck:
Alterations to services at Frome
Due to a points failure at Frome the line towards Castle Cary is blocked.
Train services running through this station may be delayed or revised. Disruption is expected until the end of the day.
Owing to a problem with a set of points (which allow trains to move from one track to another) West of Frome we are unable to run trains between Frome and Bruton or between Bruton and Frome. Trains will run directly from Westbury to/from Bruton.
A minibus has been arranged to convey customers between Frome and Westbury.
Network Rail engineers are on site and investigating the fault.
First Bus route D2: Bath (Bus Station) - Frome (Market Place) are conveying passengers via any reasonable route until further notice.
Buses running from Frome to stations towards Weymouth. Love the explanation as to what a set of points does
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by WSW Frome at 10:56, 11th October 2017 | ![]() ![]() ![]() |
Yesterday we joined the 16.29 FRO-BRI at Frome on time. The train then stopped almost immediately at Frome North Junction. We were advised that there was a points problem at Clink Road and that the train would now reverse - all the way to East Somerset Goods Loop (at Witham Friary). This was done efficiently and we then set off for WSB directly arriving about 20 mins down. The train then proceeded fast to Bath arriving about 10 mins down. So all this was quite an efficient recovery. Passengers for Trowbridge and Bradford were catered for by the immediate following train. Avoncliff and Freshford passengers "may" not have fared so well.
Such a lengthy reversal always seems a bit bizarre but no doubt necessary to make a "permitted" signalled movement. Points failures on the Frome loop are not uncommon so why cannot the problem be "properly" fixed?? The immediate problem was fixed for later in the evening. Although this was a minor event it just adds to the raft of signalling problems occurring every day now.
| Re: Frome Station Posted by WSW Frome at 16:51, 12th April 2016 | ![]() ![]() ![]() |
Points to note are that some progress is already apparent in Frome. We have had an additional (all year) Sunday service for a while - in from WSB and out to BRI at around 11.40. The Summer Sunday service has started at Easter this year, ca 7 weeks earlier. Every little helps.
Frome Town Council have plans to improve access to the station mainly from Housing Developer-provided funds. This will mainly be improved pedestrian links/signs/crossings. Doubtful whether bus connections will be improved as most bus services are in decline in Frome and elsewhere. First did try extending the 234 service at the station for a while but that obviously did not work very well.
Improved timetabling, rolling stock availability and perhaps track layout improvements towards Clink Road Junction are the only likely ways forward. SW Trains may also provide more but they will wish to review after 1-2 seasons.
| Re: Frome Station Posted by Chris from Nailsea at 20:25, 10th April 2016 | ![]() ![]() ![]() |
From the Frome Standard:
^15k windfall to create better transport links to rail services
Frome Town Council has secured ^15,000 in funding from First Great Western's Community Improvement Fund.
The project aims to increase access to rail services for low income residents through discounted tickets, promotion, affordable car and bike hire and new bus links.
The council has said it will be working closely with First Great Western to explore opportunities to increase services at the station as part of the project.
The town council's resilience officer Anna Francis secured the funding. Ms Francis said: "This is a great opportunity to look at ways we can increase access to public transport in Frome. We will be working with Fair Frome, Frome's job centre and others to offer discounted tickets and easier routes. We will also be talking to local bus companies about linking up services with the railway station. And as part of the wider programme, we will be improving signage and pedestrian access."
| Re: Lift Share Initiative for Frome Commuters Posted by TaplowGreen at 06:02, 29th July 2015 | ![]() ![]() ![]() |
Nice idea, but how many people can you realistically get in a tractor?
| Lift Share Initiative for Frome Commuters Posted by Chris from Nailsea at 01:46, 29th July 2015 | ![]() ![]() ![]() |
For the whole of August trains from Frome to Bath Spa will be replaced with buses as the line is upgraded and electrified.
In response a lift share evening is taking place at 7pm at the Three Swans pub on King Street this Wednesday to link people up who drive or get the train to Bath or Bristol regularly.
Anna Francis, Frome Town Council's energy and recycling Officer said: "We know that over 1,500 people drive out of Frome to Bath and Bristol every day. Enabling people to link up and share lifts is a great way to cut journey costs, congestion and carbon, so do pop along if you can."
As well as the face to face link up there is also a Somerset Liftshare website and app so if you can't make the event you can sign up for free at: https://somerset.liftshare.com/
The rail replacement service is part of a ^7.5billion electrification programme which has now reached the First Great Western Line at Bath Spa, allowing faster, more efficient trains. This may also free up more diesel carriages for Frome. A full timetable of the changes is available here https://www.firstgreatwestern.co.uk/bath2015
| Re: Frome Station Posted by thetrout at 16:02, 28th February 2015 | ![]() ![]() ![]() |
It seems that I cannot count. You are quite right stuving - my apologies.
| Re: Frome Station Posted by stuving at 18:15, 27th February 2015 | ![]() ![]() ![]() |
So it can be done on 1 Track already however it takes 15 minutes for a HST to take the Frome Branch line and to call there. So the risks to punctuality must be considered.
Really? 1J99 is an HST that is timetabled to do Blatchbridge Jn to Clink Road Jn in 6^ minutes. It is, after all, less than two miles plus a stop. So the gain from doubling would be small.
If you were concerned about even that time, it might be because a train running late could cause another to wait on the main line. In that case surely you would be better advised to reinstate the other platform.
But that is where the historic status might rear up and bite you - you'd need a footbridge plus plus lifts for access (on both equality and safety grounds). I can only suggest making both platforms as long as the space available, which looks to be a 10-car IEP or thereabouts. Then you can put even an unsightly footbridge so far away it can't easily be seen at the same time as the station building.
| Re: Frome Station Posted by thetrout at 17:40, 27th February 2015 | ![]() ![]() ![]() |
Does this cause much of a problem? I mean, OK, if English Heritage get involved they may ask NR to reinstate the broad guage tracks...
Truth be told, I have absolutely no idea. But I vaguely recall some time ago that there were issues regarding the colour of the station building when it came to painting it...
I also agree with grahame that no Westbury bound trains between 09:35 and 15:01 on a winter Sunday is pathetic!
With regards to the 2 hour gaps in the timetable. I am very conscious of the bus services to Bath and Trowbridge of which there are 2 and 3 per hour retrospectively.
Faresaver run their X34 service to Trowbridge, Melksham and Chippenham upwards of every 30 minutes. It's a reliable and punctual service. However to Chippenham takes forever. Their 267 service is also hourly and takes around 40 minutes to complete the journey depending on traffic.
First Bus offer a 234 and 267 service both running hourly and taking slightly longer routes via Rode. Also a reliable and punctual service.
| Re: Frome Station Posted by Red Squirrel at 10:40, 27th February 2015 | ![]() ![]() ![]() |
What also doesn't help is Frome being one of the Oldest Railway Stations in the Country has made it a listed building...
| Re: Frome Station Posted by grahame at 21:18, 26th February 2015 | ![]() ![]() ![]() |
Been a long time writing this - writ before the reply from thetrout, hence some duplication?
Quoting for critical review ...
Conservative Parliamentary Candidate for Frome and Somerton, David Warburton, met with Rail Minister Claire Perry last week.
He said due to Frome's rapid expansion, the town needs better links to the capital, and hopes it will become a reality.
He said: "Fast and efficient rail links to Frome must form a vital part of the infrastructure for the future, and a fast train service to London would represent a massive benefit for local people, businesses, tourism and the economy in general.
and
Former chairman of the Frome Public Transport Users Association, John Leach, said he believed it would not be feasible in this time of austerity.
Mr Leach said: "Frome has been a single line station since 1968 and in order for it to become a double line, a new bridge would have to be built by the former First and Last pub, which would cost millions of pounds.
"The station is well used by residents and commuters, that is not in doubt, but the answer is more rolling stock from suppliers for larger trains. Mr Warburton's plans just aren't feasible in this current economic climate. I fear it is more of an electioneering stunt to get people to support their ideas."
And that review:
I wouldn't care to say whether this is an early feasibility suggestion, something that's well researched, or indeed electioneering. In my view, the current service at Frome is sparse; any town of over 20,000 in the BaNES / West Wilts / North Wilts / Mendip economic area with a station could really do with an hourly service, and a gap from 09:35 to 15:01 on winter Sundays is dire, with 2-hour gaps during the day on weekdays being something that could do with infilling up to an hourly service. But I'm not convinced that an hourly service would need a second track. An examination of upcoming timetables sees scheduled trains at 13:44, 14:03, 14:41, 14:50, 14:59, 15:31, 15:47 and 15:55 on Mondays to Fridays, and it would seem to my (perhaps simple) mind that it's trains not tracks through the station that are needed.
Here are some things which might allow dramatic improvements at Frome:
* Re-arranging other local Westbury terminators and local trains passing through Westbury to and from the south to provide a more even service and better stock use for everyone
* 2 extra trains each way per day with re-diagramming of South West trains, London to Yeovil
* Provision of additional carriages / trains
* Updating of signalling and layout between Frome and Clink Road Junction to avoid freight blockage pinch points
* Relay existing track at Westbury Station platform 0 to allow robustness of operation there
* Resignalling of onward routes beyond Westbury to allow better than 35 minute headway.
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by thetrout at 21:06, 26th February 2015 | ![]() ![]() ![]() |
Agree mostly with all the timetable points here... But there are some considerations to be made in terms of the existing offering.
Coming the other way, extending the 17:36 from Swindon to give a Frome arrival at 18:31 would fill their 17:49 to 18:49 gap, giving an extra Bristol departure at 17:23 (by connection) between the 16:49 and 17:49.
I could see this causing problems for 2 reasons.
the 19:06 Frome - Bristol Temple Meads train is booked to arrive at 19:00 and sit in the station for 6 minutes. This allows an UP London Paddington train the chance to overtake IIRC.
The 18:49 Frome - Weymouth is a peak time train from Bath Spa & Bristol Temple Meads and is usually a few minutes late...
This leaves the risk possible for an 18:31 arrival being say 10 minutes late. You then have another 2 trains, 1 each in opposite directions all wanting a path in Frome in addition to anything InterCity grade on the avoiding lines. So what do you do to prevent that 19:06 from hogging the UP line thus meaning the InterCity service needs to slow down or stop completely around the Witham Friary area?
We know that what should happen is allow the 19:06 into the station and get the 18:31 and 18:49s to sit at the signals in the branch lines... The 18:49 also connects at Castle Cary for an Exeter St Davids / Plymouth* train so delay to this is bad news for anyone wanting to go anywhere near Penzance
I don't think it's a silly idea. But I could see FGW having some justified concerns to the punctuality of their Long Distance services. Perhaps for the more insidious reasons that trains through Frome aren't well known for their timekeeping except a small handful of trains which are either on time or cancelled in full
| Re: Frome Station Posted by thetrout at 20:52, 26th February 2015 | ![]() ![]() ![]() |
I have personally met with Mr Warburton in Routes Youth Cafe and he does seem a rather switched on chap. However I feel he may have severely underestimated the requirements needed to double track Frome Station.
What would probably build the case for double track any renewal works taking place in the Westbury area which means the InterCity services would use Frome for bustitution to Westbury and continue forward to Pewsey/Newbury etc. This has been done before on several occasions - particularly Sundays and when points have failed in the Westbury Area.
So it can be done on 1 Track already however it takes 15 minutes for a HST to take the Frome Branch line and to call there. So the risks to punctuality must be considered. Not to mention we all know what Westbury Signallers are like... That also doesn't take into account the Stone Trains to Whatley via Frome North Junction. Finally the few trains that terminate and reverse there - or sit in the Platform for 10 minutes!
Don't get me wrong I'd love to see more services through Frome. But the current layout of the station offers little prospect; particularly for anything of InterCity standard.
There is also consideration for South West Trains to run services via Frome. Also very welcome and I hope FGW allow them to fill in the huge 3 hour service gaps in the timetable we have. Heck it might even open more journey oppertunities for FGW by passengers using SWT to Westbury / Castle Cary to connect to FGW from there... Albeit probably embarrassing FGW
Oh and we then might have some genuine competition for rail travel.I should also mention that the 2 current London Paddington trains from Frome per day take longer than the other options to change trains at Bath Spa, Swindon and/or Westbury.
But we still have the generation of Fromies who insist that changing trains from Diesel to Electric traction at Westbury or Newbury is too much trouble... Yet for 90% of journeys to London... We kinda have to do that anyway
All in all if SWT get permissions to run trains through Frome in addition to anything further that FGW apply to their existing offering... I would probably call this out as a bad thing due to the congestion that it would probably cause. However this very hypothetical disruption could build a solid case... But ultimately we need people to use the trains...
Finally... It's farcical that Avoncliff gets a better service than Frome does however
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by Oberon at 08:34, 26th February 2015 | ![]() ![]() ![]() |
The prospective candidate for the Somerton & Frome seat David Warburton has been talking about the local railway.
http://www.fromestandard.co.uk/Candidate-raises-possibility-second-rail-line/story-26081873-detail/story.html?
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by phile at 15:56, 25th February 2015 | ![]() ![]() ![]() |
Thanks for the reply I was looking for. Cleared it up now.
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by Network SouthEast at 11:24, 25th February 2015 | ![]() ![]() ![]() |
Both Westbury and Gloucester drivers and guards both have booked work over the Melksham line.
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by Rhydgaled at 07:42, 25th February 2015 | ![]() ![]() ![]() |
No, as ReWind said both Gloucester and Westbury depots have drivers that sign the route through Melksham.
They may sign it but not actually have booked worked over it, just in case of diversions etc.? Although there would probably need to be alot of route learning services to allow the other group to refresh their route knowledge if that was the case.| Re: An extra service to Frome from May 2015. Potential for another??? Posted by IndustryInsider at 22:24, 24th February 2015 | ![]() ![]() ![]() |
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by phile at 19:14, 24th February 2015 | ![]() ![]() ![]() |
Yes, and if breaks are tight they'd be nothing stopping one of the Westbury drivers being rostered to bring the train off the depot and take it to Frome and back to Westbury to be relieved by the Gloucester driver to take it on to Swindon. That's if there's any slack in the Westbury drivers allocations at that time of the morning of course. I guess my point was that whilst shuffling round the guards and drivers is probably not an insurmountable task, it does need to be considered.
Does that mean that Gloucester drivers are actually diagrammed to all services via Melksham rather than shared with Westbury ?
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by IndustryInsider at 15:06, 24th February 2015 | ![]() ![]() ![]() |
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by ReWind at 17:49, 23rd February 2015 | ![]() ![]() ![]() |
Westbury & Gloucester both sign the Melksham branch.
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by phile at 17:02, 21st February 2015 | ![]() ![]() ![]() |
Frome is out on a limb a little bit, but my experience is that the little station provides plenty of passengers for each train, and plugging gaps in the service (such as that that will be plugged around the 2pm mark) only makes the station more attractive to its residents. Minor tweaks leading to quick wins can be as important as more comprehensive changes sometimes!
The changes you suggest, sound, in principle, excellent ideas - especially the morning tweak. Though that one would require an alteration to the drivers diagram (and maybe the guards as well?) as they are currently having their PNB (Physical Needs Break - in other words their break!) at the earlier time they would have to be taking the set off of Westbury depot. That might not be too difficult to change, but it does show that it's not always as easy as just having a train and a path.
I've attached the relevant drivers diagram, so you can see what I mean:
Do Gloucester crews work all the Trans-Wilts or are not Westbury involved at all.The changes you suggest, sound, in principle, excellent ideas - especially the morning tweak. Though that one would require an alteration to the drivers diagram (and maybe the guards as well?) as they are currently having their PNB (Physical Needs Break - in other words their break!) at the earlier time they would have to be taking the set off of Westbury depot. That might not be too difficult to change, but it does show that it's not always as easy as just having a train and a path.
| Re: An extra service to Frome from May 2015. Potential for another??? Posted by grahame at 12:07, 21st February 2015 | ![]() ![]() ![]() |
Much appreciate that feedback and insight - I'm aware of the break issues in principle, but staff rotas are more difficult to deduce than train rotas so at best it's an educated guess. Another guess (on that same rota) suggests to me that moving the 08:49 ex Swindon to 08:36 would also be a break issue
- pity, as that's another "small change, big improvement" candidate as it would make southbound commuting more attractive, and (as I'm posting in Heart of Wessex) also provide a connection onward to Frome and stations to Weymouth which would be greatly used in summer!| Re: An extra service to Frome from May 2015. Potential for another??? Posted by IndustryInsider at 10:59, 21st February 2015 | ![]() ![]() ![]() |
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by grahame at 07:59, 21st February 2015 | ![]() ![]() ![]() |
The TransWilts timetable changes this May - a Monday to Friday run is extended to and from Frome (arrive 13:43, leave 14:04), and the Sunday TransWilts service is recast. Both are excellent moves, both for the improvements they provide and showing an integrattion of the current trial service on the TransWilts with other services (the Sunday changes) and lines (the Monday to Friday extension). See http://www.firstgreatwestern.info/coffeeshop/index.php?topic=15401.0 for more detailed post.
The question arises "so - can there be any other similiar gains" and I take a look at the possibility of starting the 07:33 from Westbury back at Frome at 07:23 - this would give an extra peak train from Frome in the 07:04 to 08:02 gap, and give an extra (connectional) arrival into Bristol at 08:29 - between the 08:06 and 09:06. Coming the other way, extending the 17:36 from Swindon to give a Frome arrival at 18:31 would fill their 17:49 to 18:49 gap, giving an extra Bristol departure at 17:23 (by connection) between the 16:49 and 17:49.
A quick glance at the timetable shows the 17:36 from Swindon arriving into Westbury at 18:21, and an 18:32 departure back to Swindon. However, this is the time of day at which the "unit switch" for the TransWilts service is made, so it is not the same train.
I'm straying a little out of my county asking this question, but there is a significant commuter flow from Frome to various places beyond Westbury, including some to Swindon, and a peak through train would, I suspect, generate extra traffic and use a unit that's available at the time. What do others think? Is this a suggestion worth making, or a silly idea?
Edit to correct typo
| Re: Frome Station refurbishment celebration to be held on Friday 21 February 2014 Posted by JayMac at 00:48, 6th March 2014 | ![]() ![]() ![]() |
These things take time. Frome wasn't built in a day...
Brilliant! Just as long as you ain't pronouncing 'Frome' to rhyme with the Italian capital. That annoys me.
I sent a snotty email to ITV Sport a few years ago, chastising their F1 team for constantly getting the pronunciation of Jenson Button's home town wrong.
| Re: Frome Station refurbishment celebration to be held on Friday 21 February 2014 Posted by bobm at 22:20, 5th March 2014 | ![]() ![]() ![]() |
[cynic]
Couldn't the Frome Standard have got their 'before' and 'after' pictures from the same end of the trainshed? Who's to say that the paint job encompasses both ends.
[/cynic]
[/cynic]
Just for everyone's peace of mind I can confirm that both ends have indeed been painted - as witnessed today.
| Re: Frome Station refurbishment celebration to be held on Friday 21 February 2014 Posted by paul7575 at 12:25, 20th February 2014 | ![]() ![]() ![]() |
Now that the the station looks respectable again, do we finally have a Frome with a view?
| Re: Frome Station refurbishment celebration to be held on Friday 21 February 2014 Posted by trainer at 11:52, 20th February 2014 | ![]() ![]() ![]() |
| Re: Frome Station refurbishment celebration to be held on Friday 21 February 2014 Posted by Red Squirrel at 10:53, 20th February 2014 | ![]() ![]() ![]() |
Andy Fant, Senior Asset Manager for Network Rail says: "The condition of the station had deteriorated significantly over its 164 years of service..."
<rant>
If the building had had no maintenance in 164 years, it would at best resemble a pile of compost by now.
Buildings that are properly maintained do not significantly deteriorate.
The problem here was that it had not been properly maintained. So rather than congratulating themselves on bringing a listed building back from the brink, maybe Network Rail should invest in some paint and procedures - much cheaper in the long run!
</rant>
| Re: Frome Station refurbishment celebration to be held on Friday 21 February 2014 Posted by JayMac at 01:09, 20th February 2014 | ![]() ![]() ![]() |
[cynic]
[/cynic]
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by Chris from Nailsea at 23:07, 19th February 2014 | ![]() ![]() ![]() |
Frome Railway Station refurbishment celebration to be held on Friday
Frome Station before
Frome Station now
There will be celebrations on Friday at Frome Railway Station to mark the completion of a major renovation project by Network Rail.
The event is being hosted by First Great Western who manage the station and run the local rail services, and the Heart of Wessex Rail Partnership whose voluntary Community Rail Team from all along the line will be there in force during the morning to help prepare the station for the event.
The Mayor of Frome, Councillor Dickon Moore and members of Frome Town Council will be at the celebrations at 12 noon.
Frome Station is a unique example of historic railway architecture of national importance due to the timber construction of the train shed, which is one of the oldest still in use.
Frome Station was originally part of the Wilts, Somerset and Weymouth Railway designed by J.R. Hannaford and opened in 1850. It is now a Grade 2 listed building.
The detailed and painstaking restoration project took over six months to complete by a specialist team from Network Rail, and cost ^700,000.
Andy Fant, Senior Asset Manager for Network Rail says: "The condition of the station had deteriorated significantly over its 164 years of service and we identified that extensive refurbishment of the timber work and a renewal of the electrical system were required to safeguard its future, not just because of its heritage status, but also due to its importance to the community of Frome given that there has been a doubling in the number of passengers using the station over the last ten years.
The project has taken longer to complete than was originally intended. Despite incredibly detailed examinations of the structure at the outset to identify the necessary works, it was only after work commenced and a truly intrusive examination of the hidden parts was possible was it realised that the extent of the work was more significant than had been anticipated.
After considering the options, Network Rail took the decision to invest the additional money needed required to ensure all the additional repairs and renewal of the timber structure identified were undertaken as part of this scheme."
Frome Station now
| Re: Frome fights plans to withdraw funding for regional rail partnership Posted by Chris from Nailsea at 20:18, 16th November 2013 | ![]() ![]() ![]() |
From the Somerset Standard:
Frome Town Council fight to keep rail funding
Frome Town Council has agreed to fight a proposal by Somerset County Council to withdraw ^5,000 funding from the Heart of Wessex Community Rail Partnership.
The partnership is a joint venture between the train operating company First Great Western and local authorities along the Bristol to Weymouth line.
At a recent external affairs committee, members learned that the proposal is due to come before Somerset County Council's Cabinet this month.
The town council heard the partnership had played a key role in coordinating volunteer activity, promotional work and securing service and station improvements over its ten-year history. The council was also concerned it could have an adverse affect on tourism for Frome. This has included improvements to Frome station.
Speaking about the proposal, chairman of external affairs, Councillor Peter Macfadyen, said: "Our worry is that the withdrawal of funding by Somerset County Council would result in other partners dropping out because Somerset is located in the middle of the route. Not only would this impact on promotion of the Bristol to Weymouth line and volunteer work along its route but also it would weaken the region's voice in influencing future investment by the train operating company, Network Rail and the Department for Transport. While the partnership is currently focused on the Bristol to Weymouth line, it has the potential to provide a strong voice for the region in relation to rail investment. This is a classic example of where saving a tiny amount of money will cascade into long term loss of volunteers, investment and regional income and a more thought through approach is required."
In addition to writing to the county council, the town council is contacting other communities along the Bristol to Weymouth line to encourage them to take action.
The county council was due to make a decision this week on the funding but it has been deferred until later this month.
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by Chris from Nailsea at 21:32, 5th November 2013 | ![]() ![]() ![]() |
From the Frome Times:
Frome Town Council has agreed to fight a proposal that Somerset County Council withdraws funding from the Heart of Wessex Community Rail Partnership.
The partnership is a joint venture between the train operating company (First Great Western) and local authorities along the Bristol to Weymouth line.
At the council^s external affairs committee, members learned that the proposal is due to come before Somerset County Council^s Cabinet in November.
The partnership has played a key role in coordinating volunteer activity, promotional work and securing service and station improvements over its 10 year history. This has included improvements to Frome station.
Speaking about the proposal, cllr Peter Macfadyen, Chair of external affairs said, ^Our worry is that the withdrawal of funding by Somerset County Council would result in other partners dropping out because Somerset is located in the middle of the route.
^Not only would this impact on promotion of the Bristol to Weymouth line and volunteer work along its route, but also it would weaken the region^s voice in influencing future investment by the train operating company, Network Rail and the Department for Transport. Whilst the partnership is currently focused on the Bristol to Weymouth line, it has the potential to provide a strong voice for the region in relation to rail investment.
^This is a classic example of where saving a tiny amount of money will cascade into long term loss of volunteers, investment and regional income and a more thought through approach is required.^
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by Mookiemoo at 23:26, 22nd November 2010 | ![]() ![]() ![]() |
Now, going up to the end of the platform to micturate is just about acceptable, but to evacuate ones bladder in full view of a dozen or so people is, in my humble opinion, a tad unacceptable.
And if I had the need and had to squat?
Sorry - its double standards
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by thetrout at 23:11, 22nd November 2010 | ![]() ![]() ![]() |
You're right super tm, I could have got the guard who was indeed at the front of the train. I'm probably a little OTT on the safety side of things (It's something i've had hammered into me since a young age, as my Dad is a Safety Director) and for that I apologise.
But I was more worried at the fact a stepped on some poor sod's foot as I couldn't see what I was doing properly - hence my comment
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by super tm at 19:17, 22nd November 2010 | ![]() ![]() ![]() |
So by the sound of it the guard was in the front coach. When he came to the back coach he found the lights had gone off so he turned them back on again. If you feel this was a safety issue may I suggest next time you find the guard and tell them about it ?
| Another 08:02 Incident Posted by thetrout at 14:46, 22nd November 2010 | ![]() ![]() ![]() |
I boared the 08:02 at Frome this morning. The train was on time
However it was a 2 car 158. Except the rear coach had no lighting... As Frome station has a canopy this made being able to see rather awkward. But this isn't my concern.
The 08:02 starts at Weymouth. So would have started it's journey during the hours of darkness (This morning it was still dark at 07:30 when I left home). Surely this is a safety issue?!
Interestingly enough I didn't think it was a train fault as you could see the light was on in the rear cab as you could see it shining through the bottom of the cab door as I got on. However when the guard who was at the front of the train came to the rear coach and completed a "Tickets from Frome" check, they switched on the lighting just before arrival into Westbury
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by tramway at 08:54, 1st November 2010 | ![]() ![]() ![]() |
Not that I wish to go on about this... But the 18:28 Trowbridge - Weymouth was delayed by 45 minutes today...
Quite a few problems, incl cancellations on Fri steming from I've been told cable theft in the Tunnel Junction area.
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by dviner at 11:52, 30th October 2010 | ![]() ![]() ![]() |
This trains delays seem to get dumped down to either a signal failure or non maintenance of a flail strip.
What the hell is a flail strip?
An area of up to 5 metres from the running rail which is clear of foliage (so it doesn't "flail" any services passing through that area). This is distinct from "gauge", which (I believe) is more to do with hard structures.
Somehow, I wouldn't want to be flailed by a bridge.
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by thetrout at 10:37, 30th October 2010 | ![]() ![]() ![]() |
I can go one better than that one BNM i'm afraid...!
I was with my friend a couple of months back, we decided to go out to a nightclub in Bristol and catch the 05:30 back to Bath...! Whilst we were down near the Hippodrome (sp?) about 3:00AM having a veggie burger and chips
We spotted a complete and utter fool dropping his trousers against a wall when he was less than 10 metres away from a Portaloo...
Just what you want to see when you're eating...!
Some people... Jeez...
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by JayMac at 00:05, 30th October 2010 | ![]() ![]() ![]() |
If it's any consolation, thetrout, I had the unenviable displeasure of witnessing a hopeless drunk taking a p*ss no more than 10ft away from me at Montpelier this morning.
Now, going up to the end of the platform to micturate is just about acceptable, but to evacuate ones bladder in full view of a dozen or so people is, in my humble opinion, a tad unacceptable. Particularly as he decided not to face away from the gathered awaiting pax. At 10am as well!!!
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by thetrout at 23:48, 29th October 2010 | ![]() ![]() ![]() |
Any other day I wouldn't have been bothered, it was the fact that it was COLD and RAINING!!But that's not what I was concerned about... I was desperately trying to not make eye contact with the local pond life... who seemed to think that messing around with the Help Points, Cycling on the platform with their BMX bikes, smoking in the waiting shelters or trying to break the glass in the telephone box on Platform 2 was acceptable...
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by at 21:26, 28th October 2010 | ![]() ![]() ![]() |
http://www.homegrowntimber.com/indexrailways.html
Edited by Inspector H Blakey to make the linky-winky work
Apologies for the unusual frivolity, normal service will be resumed in the morning when i'm sober again| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by inspector_blakey at 21:24, 28th October 2010 | ![]() ![]() ![]() |
Appears to be something used in trimming back vegetation... http://www.gesgkft.hu/eng_railway_chemical_weed_control.html. So at a bit of a guess, maybe there was a yellow machine doing a spot of lineside topiary that expired and got in the way?
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by SDS at 20:54, 28th October 2010 | ![]() ![]() ![]() |
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by thetrout at 17:41, 28th October 2010 | ![]() ![]() ![]() |
think you will find there is a speed restriction on the Weymouth line imposed due to condition of track also leaf fall season dosent help
Thanks for this dog box
I seem to be plagued with delays on this route, another train that is normally a few minutes behind is the 17:28 Trowbridge - Weymouth service. But this doesn't normally affect me too much as I either take the bus to Frome as it takes me closer to where I live
As much is prefer trains, I may have to start taking the Bus to work...
oh the delights of the 234.........
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by eightf48544 at 08:35, 28th October 2010 | ![]() ![]() ![]() |
It's the 0540 that's the 4-car from Westbury.
Apologies!
Apologies!
You get up early in the West Country!
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by fatcontroller at 16:46, 27th October 2010 | ![]() ![]() ![]() |
Sorry - that was me being dense.
Apologies!
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by tramway at 15:54, 27th October 2010 | ![]() ![]() ![]() |
So that's where all the stock is going, the aliens are grabbing 2 of them between Westbury and Trowbridge as the 08.23ish d. TRO is 2 cars AFAIK when (if) it turns up. It certainly still was according to a colleague who managed to squeeze on this morning.
Stopped using it many months ago.
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by fatcontroller at 14:25, 27th October 2010 | ![]() ![]() ![]() |
Consistently late and always full and standing, it should really be 4 car from Westbury.
It is a 4-car from Westbury
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by SDS at 09:59, 27th October 2010 | ![]() ![]() ![]() |
Power failure at Yeovil pen mill (IE)
Non maintain of a flail strip (?) (JP)
Regulated (YO)
signal failure (IA)
Regulated at BRI (YA)
Sorry for codes will update codes later, rushing to post this.
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by dog box at 09:42, 27th October 2010 | ![]() ![]() ![]() |
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by tramway at 08:18, 27th October 2010 | ![]() ![]() ![]() |
| Re: 08:02 Frome - Bristol Parkway Service (A Rant) Posted by SDS at 15:26, 26th October 2010 | ![]() ![]() ![]() |
08:02 log
Headcode: 2D05 UID: P11851 26/10/2010 0640 Weymouth [WEY] to Bristol Parkway [BPW]
This Train is operated by First Great Western.
[Refresh]
Location FD Scheduled Arrival Scheduled Departure Expected Arrival Expected Departure Pl Lateness DR
Weymouth [WEY] 0640 0640 1 On time
Upwey [UPW] 0645 0645 0644 0646 1 1
DRCHJN Pass 0651 Pass No log
Dorchester West [DCW] 0652 0653 0654 0655 1 2
Maiden Newton [MDN] 0703 0705 No log 0708 3
Chetnole [CNO] 0713 0713 No log No log
Yetminster [YET] 0716 0716 No log No log
Thornford [THO] 0718 0718 No log No log
Yeovil Pen Mill [YVP] 0726 0730 0731 0743 1 13
Castle Cary [CLC] 0743 0744 0756 0758 3 14
Bruton [BRU] 0749 0749 0802 0804 1 15
ESTSOMJ Pass 0755 Pass 0810 15
BLBGJN Pass 0759 Pass 0816 17
Frome [FRO] 0802 0802 0817 0819 17
FROMNSB Pass 0803 Pass No log
CLNKRDJ Pass 0804 Pass 0821 17
FRWDJN Pass 0809 Pass 0824 15
Westbury [WSB] 0813 0817 0827 0828 3 11
HWKRJN Pass 0818 Pass No log
Trowbridge [TRO] 0822 0823 0833 0835 12
BRDFDJN Pass 0825 Pass 0837 12
Bradford-on-Avon [BOA] 0828 0829 0840 No log 1 12
Avoncliff [AVF] 0831 0831 No log 0846 1 15
Freshford [FFD] 0834 0834 No log 0849 1 15
BTHMPTJ Pass 0842 Pass 0854 12
Bath Spa [BTH] 0845 0847 0900 0901 1 14
Oldfield Park [OLF] 0849 0849 No log 0905 16
Keynsham [KYN] 0856 0857 0912 0913 16
NSMRSTJ Pass 0902 Pass 0918 16
BRSTLEJ Pass 0903 Pass No log
Bristol Temple Meads [BRI] 0905 0910 0923 0925 1 15
BRSTLEJ Pass 0911 Pass No log
DRDAYSJ Pass 0911 Pass 0927 16
Lawrence Hill [LWH] 0913 0913 No log No log 1
Stapleton Road [SRD] 0915 0915 0930 0931 1 16
STPLNAR Pass 0917 Pass 0931 14
Filton Abbey Wood [FIT] 0921 0922 0935 0936 2 14
Bristol Parkway [BPW] 0928 0940 4 12
[Refresh]
This morning it was 11 late according to systems.
Lost time between Maiden Newton and Yeovil.
Without looking at TRUST I cant give you an exact reason for the original lateness. I would guess the later delays would be due to the train having lost its slot on the GWML.
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by thetrout at 14:46, 26th October 2010 | ![]() ![]() ![]() |
I catch the 08:02 service from Frome now most days since starting a new job 5 weeks ago
I would say on most of the days i've caught it, this service has been late. This is incredibly irritating
as I have a connecting bus service at 08:25 - admittedly a tight connection, but I have made it by a brisk walk! On the face of it though, it's not that tight a connection as the train is ment to arrive at 08:13 at Westbury which leaves ample time to walk to the bus stop!This morning and yesterday morning the service was 20 minutes late upon arrival into Westbury. I am now ^15 lighter due to paying for a taxi. Admittedly my own choice as I could have waited for the 09:00 264 but decided against waiting in the cold and the rain for 35 minutes
So my question is, why is this train consistantly late?? and if this is going to be a regular occurance, would I be better off booking a contract taxi to work...?? (I get a significant discount with a certain firm
)Rant over
| Re: Police issue CCTV images after theft of passenger's handbag at Frome on 2/5/2010 Posted by Brucey at 16:04, 22nd May 2010 | ![]() ![]() ![]() |
A thought has occured to me. It's all well and good BTP putting these details on their website, but would it not be better, and perhaps more likely to identify the miscreants, if posters displaying these pictures were put up at stations along the routes where incidents are alledged to have happened?
Also posters on the train would help as people might actually spot the offender whilst they are travelling (or at least discourage him from doing it again after seeing himself on a poster)!| Re: Police issue CCTV images after theft of passenger's handbag at Frome on 2/5/2010 Posted by 6 OF 2 redundant adjunct of unimatrix 01 at 22:03, 18th May 2010 | ![]() ![]() ![]() |
i think there should be a group on facebook offering rewards, not saying that i personally would want a reward for passing on info but it would get peoples attention
| Re: Police issue CCTV images after theft of passenger's handbag at Frome on 2/5/2010 Posted by Chris from Nailsea at 21:28, 18th May 2010 | ![]() ![]() ![]() |
Agreed, bignosemac - and I think it would be helpful if more local newspapers picked up these stories and published the details - and pictures - as well!
| Re: Police issue CCTV images after theft of passenger's handbag at Frome on 2/5/2010 Posted by JayMac at 21:16, 18th May 2010 | ![]() ![]() ![]() |
| Frome station - facilities, services, improvements, events and incidents - merged posts Posted by Chris from Nailsea at 20:26, 18th May 2010 | ![]() ![]() ![]() |
From the BTP press release:
BRITISH TRANSPORT POLICE ISSUE CCTV IMAGES FOLLOWING THEFT OF PASSENGER'S HANDBAG - SOMERSET/WILTSHIRE
British Transport Police (BTP) officers are appealing for the public^s help to identify a man they would like to speak to in connection with the theft of a passenger^s handbag from on board a train.
Officers have today released CCTV images of the man they believe can help with their enquiries into the incident which took place shortly after 9.30am on Sunday 2 May.
A 37-year-old passenger boarded the 0940hrs Frome-Bristol Temple Meads service at Frome station and placed a number of bags on a seat before going into the vestibule of the carriage to talk to another passenger.
When she returned to her seat around five minutes later, she discovered that her handbag containing a mobile telephone worth ^100 and some personal items was missing.
PC Jason Teear (corr) of BTP said: ^After viewing CCTV footage from on board the train we have identified a man who we would like to trace as we believe he may have information which could assist us.
^I would urge anyone who knows the identity of the man in the CCTV pictures, or who knows his whereabouts, to contact British Transport Police in confidence.
^As you can see from one of the photographs, he has a distinctive hairstyle at the back of his head and I believe that someone will recognise him. He got off the train at Westbury rail station so it may be that he lives in that area.^
| Re: Frome Fatality - 27 November 2009 Posted by Chris from Nailsea at 20:20, 30th November 2009 | ![]() ![]() ![]() |
Hi, portwine, and a rather sombre welcome to this forum.
Looking around other topics here, you will see that there are unfortunately many cases of people choosing to find their own peace in such a way.
As always in such incidents, our thoughts are with the train driver and crew, and the family and friends of the deceased.
Thank you for your comments.
| Re: Frome Fatality - 27 November 2009 Posted by portwine at 20:07, 30th November 2009 | ![]() ![]() ![]() |
Hi,
i was on this train. I'm still thinking about this person. i hope they have found peace.
